07-01-2010, 11:00 AM | #1 |
Rock Stacker Join Date: May 2009 Location: Baton Rouge
| ax10 leaking shock caps
I have a kit ax10 with the plastic shocks. And the caps keep leaking. Are there any other shock caps that fit. I do not want to buy new shocks. But I need a cheap fix. THANKS |
07-01-2010, 11:28 AM | #2 |
Rock Crawler Join Date: Jul 2009 Location: boise
are your shock bladers in corectly? also if the caps are too tight they can mess up the seal of the balder.
07-02-2010, 10:27 AM | #3 |
Newbie Join Date: Jun 2010 Location: Northern CA
I'm with you man, I have the AX10 plastic shocks and they suck, as much as I don't WANT to replace them, I'm pretty sure I'm going to soon, anyways. I'm getting tired of those things falling apart for practically no reason. I was thinking about the Losi crawler shocks or the integy ones. I want a slightly shorter shock (4 inch) for my new chassis, and I've had people suggest them both, so it'll probably depend on whats out there when I have the money to blow. |
07-07-2010, 07:33 AM | #4 |
Will Aluminum Shock Caps help on the plastic body shocks? they have these on epay( item # 230494820847 ). THANKS |
07-07-2010, 10:05 AM | #5 |
Pebble Pounder Join Date: Jun 2010 Location: pelham
07-07-2010, 12:40 PM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Axial plus STRC makes alum bodys and caps but for few more $ ya can get invaders/losi/traxxas big bores.
07-07-2010, 01:02 PM | #7 |
Thanks for the replys. I was given 4 stock t maxx shocks. With very lil use. Just need to see how I can mount them. Would these be "big bore shocks"?
07-07-2010, 08:12 PM | #8 | |
Search rod end mod for mounting. Basically cutting the mounting hole part off the cap, drilling & tapping the center of the cap 3mm and screwing a 3mm screw on the cap to thread a small traxxas rod end to. | |
07-08-2010, 09:03 AM | #9 |
Newbie Join Date: May 2010 Location: Brunei Darussalam
i did face the same problem.. as a temporary solutin..u just seal the cap using thread lock while saving some money to get Gmade shock |
