07-26-2010, 02:30 AM | #1 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
| VP zero ackermann knuckles
So, a couple days ago, I placed an order for some zero ack knuckles. Right now, my rig is setup Sportsman, so good steering is a must. Standard knuckles (stock and aftermarket) have a really bad reverse ackermann, causing the outside tire to turn sharper than the inside tire. Well, I just could not take it anymore, and I ordered a good set of knuckles. Question: I found a BTA "kit" on RPPHobby that is for BTA and 4 linking...however, it says it does not work with the zero ack knuckles. Could someone explain to me what the difference is? is it because the tie rod is not set for that length? Is there some other issue? Am I going to have trouble setting up BTA with these VP zero ack knuckles? Discuss. Casey |
07-26-2010, 05:19 AM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
you can make anything work if you want it to |
07-26-2010, 05:22 AM | #3 |
07-26-2010, 05:29 AM | #4 |
If it's this kit I would say the reasoning is just because of the tie rod isn't long enough to reach from knuckle to knuckle. http://www.rpphobby.com/product_p/ldrste001.htm But if you plan on redoing it all anyway why buy the kit? |
07-26-2010, 05:48 AM | #5 | |
Casey | |
07-26-2010, 06:27 AM | #6 |
I gotcha. kinda missed what you were asking at first |
07-26-2010, 07:56 AM | #7 |
It's because when there is no ackerman in the knuckle, the hole in the arm is the same distance apart as the knuckle kingpin (pivot). This makes the holes a bit further apart on the zero ackerman knuckles and if you used the tie rod for ackerman knuckles (shorter), you'd end up with a bit of toe-in since a knuckle with ackerman has a kink in the arm so that it puts the hole on the arm inboard of the knuckle pivot point. Vise-versa, if you used a tie rod meant for zero ackerman knuckles on knuckles with ackerman...you'd get some toe-out.
07-26-2010, 09:04 AM | #8 | |
07-26-2010, 09:24 AM | #9 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Offroader5's statement is correct for a front mount tierod setup. DickyT's response is correct for a BTA setup- the toe-in, toe-out is reversed. I think KCJones has the tools and smarts to make his own stuff, but if he wants to save some time, he could just buy a battery/servo plate with 4 link holes, and fab up the rest. If you have Ackerman knuckles, you can use toe-out in a front mounted tierod to help correct the angles at full turn, conversely, you use toe-in to correct in a BTA setup. Tie rod needs to be spaced/fabbed so the tires are parallel at full lock. Last edited by gunnar; 07-26-2010 at 09:30 AM. |
07-26-2010, 10:01 AM | #10 | ||
07-26-2010, 10:48 AM | #11 | |
Yeah, I am trying to make full use of the cheap labour that surrounds me each day. Also, I can design, and get a prototype in about 24 hours, where as if I order up something from the states, it take nearly 3 weeks to get here. I think I will fab up my own. | |
07-26-2010, 11:07 AM | #12 |
Rock Crawler Join Date: Jul 2009 Location: boise
i used the stock battery tray form the AX10 and drilled holes and cut it up for the front 4 link, battery, and servo... so it was free for me.
07-26-2010, 01:03 PM | #13 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
The tierod length (eye to eye) for zero ackerman knuckles is right at 6". You can build your own BTA set-up fairly easy. If your running the tie rod in the front, you can get away with a Lundsford 140mm Rock Grinder link. TOM |
07-26-2010, 02:07 PM | #14 |
Ideally, for a BTA setup, you'll want to use standard high clearacne knuckles as opposed to zero ackerman knuckles. Using the standard knuckles in a bta setup will give you "true" or "correct" ackerman in which the indie tire turns sharper than the outside tire. So rule of thumb is zero ackerman for standard steering, and standard knuckles for bta steering. |
07-26-2010, 04:32 PM | #15 | |
I'm going to have to disagree with ya on that one. With the axles being locked, you want BOTH wheels turning to full lock on the CVD's. There is no reason to have the outside tire not turning as sharp as the inside tire. It's not like with a crawler your trying to reduce tire scrub (which correct ackerman does). And like Casey said, in Sportsman class, every bit of steering is a must. TOM | |
07-26-2010, 05:28 PM | #16 | |
And as far as a tie rod. The 5/1" long revo stainless tie rod will work. Dubro rod ends are a better choice than the revo ends for that application though. | |
07-26-2010, 06:08 PM | #17 |
Rock Crawler Join Date: Jan 2009 Location: crawlorado
ive built up a system that works well....it will be shown soon in my fastback thread.......ill give you a hint stock axial links a couple spacers a few bends poof mine works great for me....sporty rig too
07-26-2010, 06:12 PM | #18 | |
07-26-2010, 06:55 PM | #19 |
Here is just one quick example of where you want both of your knuckles turning to full lock with VP Zero Ackerman knuckles. This is Chris the Battery Man at the AWCC Last Chance Qualifier. If the outside tire didn't turn that extra 2 or 3 degrees, Chris wouldn't have been able to hook his right front tire on the rock and clear the gate without a reverse. |
07-26-2010, 07:26 PM | #20 | |
