07-26-2010, 09:08 PM | #1 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
| ax10 that has steering but no throttle
my ax10 got put aside for about 2 weeks with out run because i was waiting for some parts still waiting but i can run it not well though i pluged in a fresh pack and it ran i small amount and then would stop then it would go again a little while latter but not it does not work (only steering no throttle) i look at trouble shooting and it said it was the battery charged another and does the same (running tekin fxr) and only lights 135 flash and it will not beep and i can not do a sell check with it cause its water proof !!!!HELP!!!!please |
07-27-2010, 12:28 AM | #2 |
What's your set up (Servo, Motor, receiver)? Are you running a dig?
07-27-2010, 05:00 PM | #3 |
motor=tekin 35 servo=hi-tec hs-5955tg receiver=Tower Hobbies 224 System 2.4 2-Channel 2.4GHz Rx |
07-27-2010, 05:14 PM | #4 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
Id say u have a loose connection
07-28-2010, 09:47 AM | #5 |
i checked nope
07-28-2010, 09:58 AM | #6 |
When the truck stops running, can you push it and it will move again under it's own power? If so, then it sounds like you have a stuck brush. Also, what ESC and are you running an external BEC? Last edited by JeremyH; 07-28-2010 at 10:05 AM. |
07-28-2010, 02:30 PM | #7 |
07-28-2010, 10:03 PM | #8 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
You said you were running a Tower Hobbies 2.4 ghz system. I have had some problems with their receivers. Because they are so cheap, I decided to purchase another receiver only, and low and behold, it works...only for a little while. The new one I just bought stopped working after 2 battery packs. A call to Tower is in order. In my case, the first receiver quit after a week. I had throttle, but no steering. With the second receiver, I have steering, but no throttle. In contrast, my Spektrum receiver, which has been fully submerged in water twice, is still going strong. |
07-29-2010, 02:58 AM | #9 | |
07-29-2010, 04:28 AM | #10 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
07-30-2010, 03:24 PM | #11 |
Newbie Join Date: Jun 2010 Location: Bozeman
You could try running a stronger BEC and maybe a better radio system I am running a futaba 4pk and my second radio system is an airtronics mx11 and I have had no problem with either but if your on a budget a spektrum dx3r or dx3s are both good as well and for the BEC I always go with a castle creations one hope it helps man!
07-30-2010, 04:19 PM | #12 |
RCC Addict Join Date: Jun 2008 Location: Fresno
led's 1, 3, 5? isnt that the lipo cut off? try disabling the lipo cut off if that doesnt work you probabbly need a bec |
