Thread: AX10 RTR and Lipo question
Old 04-03-2010, 09:12 PM   #1
Default AX10 RTR and Lipo question
My friend has a AX10 RTR racer/crawler kit and the guy at the hobby shop sold him some losi lipo's for it. First off can you run lipo's on the factory ESC that comes with that kit? If so do you have to change the plugs on the crawler to match what came on the battery?(a weird little plug, I haven seen it before, it's not a dean) Thanks for any help, we're both newbs. to RC's altogether.
Tdog is offline   Reply With Quote
Old 04-03-2010, 09:17 PM   #2
0 0
romulus22's Avatar
once you figure out the plug situation yes you can use them but you must not run them to low. either get a lipo cutoff by novak or buy a lipo cutoff ESC. make sure he doesn't try to charge them with a non lipo charger too
romulus22 is offline   Reply With Quote
Old 04-04-2010, 04:46 PM   #3
Make sure you only run 2s lipo's with the stock ESC, a 3s lipo will fry it.
Jive
Jive is offline   Reply With Quote
Old 04-04-2010, 04:54 PM   #4
Buy yourself some Deans connectors too. They come in packs, and they are cheap. Set all of your batteries, and your esc up with those. Welcome to crawling, and to RC!
Mayze is offline   Reply With Quote
Old 04-04-2010, 05:58 PM   #5
Suck it up!
Duuuuuuuude's Avatar
Jive
No they won't.
Duuuuuuuude is offline   Reply With Quote
Old 04-04-2010, 07:44 PM   #6
Originally Posted by Duuuuuuuude View Post
No they won't.
Agreed.....No they won't.
crawlerpillar is offline   Reply With Quote
Old 11-20-2010, 10:21 PM   #7
Default Connectors
What connector does the stock esc have out of the box? I'm thinking of getting one but i dont know what battery to get and what connector i need.
Thanks!
cooperh is offline   Reply With Quote
Old 11-20-2010, 10:25 PM   #8
X3
I have ran mine with a 15t motor on 3s before, you just have to stay out puddles
ax-10 crazy is offline   Reply With Quote
Old 11-21-2010, 03:48 PM   #9
Default They will work!
I have a stock AX10 rtc. I run a 3s 2200 lipo in mine. It made it come alive and i have not had any problems. Just dont let it run to low or your chances of damage are greater.
jonbidwell is offline   Reply With Quote
Old 11-21-2010, 08:11 PM   #10
how many volts does your battery have? how many can the esc take?
Thanks
Old 11-21-2010, 08:26 PM   #11
Get a new esc that has a lipo cutoff you will thank me later. The stock esc isnt very good and will blow your batterys with out a cut off
losichris is offline   Reply With Quote
