Thread: AX10 Tranny vs 12T motor
Old 03-23-2011, 01:27 PM   #1
Default AX10 Tranny vs 12T motor
Anyone think the stock tranny (with steel gears in tranny and in each axle) could handle a 12t motor? I have an AX10 then built an XR10 so I just want to have the AX10 as a basher. I put the stock ESC back into the truck as well. Thanks!
armycrawler101st is offline   Reply With Quote
Old 03-23-2011, 01:43 PM   #2
Arrow
Crawling won't be an option. Now rock racing is a potential. I would be curios to know how long those axles will hold ? Also, how much torque it would have ? Can you say SNAPPY !
DRV KRAWLER is offline   Reply With Quote
Old 03-23-2011, 01:47 PM   #3
get some MIPs or Junfacs. Stock shafts wont last long. Isn't there a motor turn limit on the stock ESC? Sounds like a helluva fun time.
YJJPWrangler is offline   Reply With Quote
Old 03-23-2011, 03:28 PM   #4
I do have MIPS installed too. I'm not sure if there is a motor turn limit or how to find out. I have my built up XR10 for crawling so I'm not concerned about that. I just want to set it up with a fast cheap motor and go crazy with it!
Anyone know the stock ESC capabilities?
Old 03-23-2011, 04:33 PM   #5
I ran a LRP 8.5t brushless for a while and the stock outputs broke, but no problems other than that
mudn_1 is offline   Reply With Quote
Old 03-23-2011, 05:12 PM   #6
Should handle it fine. I've put a 4300kv brushless on 3s into mine before...didnt even blink an eye.
I would recommend decent drive shafts & steel outputs.
The stock AE-1 ESC can handle down to a 15t 540 which is about the same as a 12t 550.
WIDELOAD is offline   Reply With Quote
Old 03-23-2011, 11:35 PM   #7
i ran an 8.5 with all robinson gears in the tranny robinson outdrive and a vanquish case. i tried to break it but couldnt. also had mip's
digitaldave303 is offline   Reply With Quote
Old 03-28-2011, 07:42 AM   #8
Dos anybody know if the stock ESC can handle a Lipo? And if so, what?
Old 03-28-2011, 09:09 AM   #9
yes the stock speedo can handle lipo but dose not have a low voltage dectection or cut off. i use mine with a 3s lvc an have had no problems with it untill it got wet
tdevilman2009 is offline   Reply With Quote
