10-31-2010, 11:24 PM | #1 |
Newbie Join Date: Jun 2010 Location: Palmer
| biggest tires on an AX10
Was wondering if anybody uses Clod or Summit size tires on their AX10. I was thinking 6" - 7" in height. I'd like a little more height and tire size for snow. Also what wheel you can use that'll bolt up. I don't really wanna buy another truck, as i've dumped a lot of $$ and upgrades in my AX10 Scorpion. Thanks!
10-31-2010, 11:26 PM | #2 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
My Proline Chisels are quite tall...and on some narrow wheels, my HB Rovers are the same height. As for really tall tires, I would argue against it, as it will put alot of strain on your drive train. Stick to around 5.5" with your tires. If you need a bit more ground clearance, try to get it another way. Casey |
10-31-2010, 11:33 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
X2 on the big tires. The other down side to really big tires is it will limit your steering. The tries will hit your front shocks or lower links faster than with normal 2.2 tires. Maybe somthing a little wider would allow you to stay on top of snow better like sedonas. I live in Texas, so can really tell you anything about that white stuff.
10-31-2010, 11:37 PM | #4 |
Newbie Join Date: Oct 2010 Location: victoria
i have some what of a stock ax10 scorpion rtc and here are the tires i'm running on it. the are imex all-t dawg tires and the width is 3" and the hight is 5.5" i'm also thinking of getting theese for my rig to raise the diff's Last edited by mowgli420; 11-01-2010 at 01:31 PM. |
11-01-2010, 05:46 PM | #5 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
i'll be keepin an eye on this one, I really want to mount clod wheels and tires onto a set of AX10 axles for a mud truck build, so hopefuly someone pipes up!
11-01-2010, 05:53 PM | #6 |
You could just read posts from two years ago. Leverage increases, things break quickly. |
11-01-2010, 05:56 PM | #7 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Get some bigger axles.
11-04-2010, 12:13 AM | #8 |
Pebble Pounder Join Date: Feb 2009 Location: WV
How about some sort of pizza cutter tire? Tall but skinny. There are a lot of Jeepers that are going in that direction and they get the benefits of a tall tire obviously but the reduced weight and tire drag really help with power, fuel economy, and broken axles.
11-04-2010, 05:13 AM | #9 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
you would want a wide tire to stay on top of the snow.... id try stock wheely kings . you should be able to find them here on the cheap and they are not to heavy to hurt your drive train |
11-04-2010, 06:46 AM | #10 |
Opps...I totally missed that the OP wanted new tires for the snow. Yeah, pizza cutters probably not the best for that.
11-04-2010, 11:37 AM | #11 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I have made a monster out of some old stock axles I had. They hold quite great with only a set of alum knuckles. Here is how I mounted the wheels. It is a simple 2.2 wheels cut and glued inside the clod wheel. The wideners are not really that necessary but I wanted some extra width. |
11-04-2010, 01:56 PM | #12 | |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
11-04-2010, 06:34 PM | #13 |
Quarry Creeper Join Date: Jul 2010 Location: Gila & Cibola
