11-01-2010, 09:01 PM | #1 |
Newbie Join Date: Nov 2007 Location: gardnerville NV
| torque twist?
just picked up another ax10 and hooked it all up and it seems to have some hard twist when you hit it full throttle, will it help when i throw some weight in the front tires? (planed on it) my old ax10 didnt seem to have this problem but it had aluminum wheels and was setup different but cant tell you how as im drawing off memory from a year ago and PBR pretty much took care of that any help would be great thanks
11-01-2010, 09:04 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
Do you have a four link set up?
11-01-2010, 09:21 PM | #3 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Tons of ways to combat TT. 1. flip your transmission around backwards. 2. Get rid of the 3 link setup, and drill some holes to connect a 4 link setup. 3. If running the lower plastic links, get rid of them and create your own out of Delrin or Aluminum. 4. Gear your front diff a bit faster than your rear diff. This will get you started. |
11-01-2010, 09:31 PM | #4 |
11-01-2010, 09:38 PM | #5 | |
| Quote: Casey | |
11-01-2010, 09:49 PM | #6 | |
11-01-2010, 09:50 PM | #7 |
Alright....turn the tranny skid around. DONE!
11-01-2010, 09:52 PM | #8 |
11-03-2010, 12:32 PM | #9 |
11-03-2010, 01:00 PM | #10 | |
4 link the rear as well, 3 linked will continue to twist regardless what other steps you take. Last edited by DickyT; 11-03-2010 at 01:05 PM. | |
11-03-2010, 01:45 PM | #11 | |
11-03-2010, 02:10 PM | #12 | |
My torque twist solution was as follows: Mirrored tranny, good chassis (stock has horrible geometry), 4 linked, 60 wt oil in left rear shock, 45 in right rear, equal length upper links on the rear mounted above the plate and on a UGC D plate after they were released, under drive rear gears, and countless hours of anti squat tuning. There are some videos of my Fastback floating around the video section that have made some doubt it was a shafty do to the lack of torque twist on mind boggling steep climbs. Last edited by DickyT; 11-03-2010 at 02:15 PM. | |
11-03-2010, 03:32 PM | #13 | |
11-04-2010, 11:22 AM | #14 |
well the PO put the tranny together backwards so i spend some time flipping the tranny all around. seemed to help some although i didnt have a full battery to completely test it. kinda hard to do it when you cant get the output shaft off because someone red locktighted them on..... saddle packs and maybe gear the front and i think it would be gravy thanks for all the info guys |
11-04-2010, 11:28 AM | #15 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
or you can take a look at what us venom guys are doing and go to rmdw's T's & T's & Setups in the venom section some of it should be pretty universal.
11-04-2010, 11:51 AM | #16 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
A little heat from a heat gun or a lighter releases the lock-tite. Saddle packs help a lot. Even with 3-links front and rear I've got my climb angle to 64 degrees and hugely better performance on the rocks by doing all the simple things like mirroring the tranny, changing to a better chasis, stiffening the rear shock oil, changing to aluminum links, going to saddle packs, etc. The most telling indication of the improvement is that when I hit the throttle on flat ground all four tires stay on the ground. Four-link setup is on the christmas list |
11-04-2010, 01:27 PM | #17 | |
11-04-2010, 01:32 PM | #18 | |
Here is one of the video's showing just how smooth a shafty can be Underground Crawlers Fastback and FF-4's at Haulover | |
11-04-2010, 02:18 PM | #19 | |
11-04-2010, 02:22 PM | #20 |
