11-12-2010, 10:51 PM | #1 |
| MIP C Splines
I have been running MIP shafts on my AX10 for a while now...it wasn't until tonight I noticed that the front shaft ends meet fairly quickly while compressing down the front. I have barely any front end compression at all before the shafts end up touching each other. I know the distance from the tranny to the front is shorter than the rear. Did I install my shafts incorrectly? Are both front and rear shafts from MIP the same length? According to TCS pictures it looks the same... http://www.tcscrawlers.com/MIP-C-Dri...1-p-16872.html |
11-13-2010, 02:26 AM | #2 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
Need a little more information, are you running the stock chassis, with the stock transmission an its stock location, if so then you should be ok, If you are running a aftermarket chassis the moves the transmission, or a aftermarket transmission, or a Dig, then that will change a lot of things, I had to take a little off the female side when I moved my transmission forward, and run the shortened version in the rear because i use a dig in mine, anyway that was the case with mine, and you may have to do something similar with yours depending on your set up. |
11-14-2010, 02:05 AM | #3 |
Ohhh....that might be the case. I am running the VP Incision chassis and the tranny is probably mounted forward a bit. Also I know MIP also makes a unit for the dig versions but I don't plan on running dig on my shafty. It's not a terrible issue since I still have decent side to side articulation. |
