11-30-2010, 08:39 AM | #1 |
Newbie Join Date: Nov 2010 Location: Folsom
| Gearing
Currently I'm using 14t pinion / 87t spur on Novak 55 motor and 3s lipo. The 3s lipo is a little fast and I'd like to gear down for smooth/slower crawl. How far down can I go in pinion or high in spur - what is recommended? (pinion / spur) |
11-30-2010, 09:11 AM | #2 |
What radio and esc are you using? Perhaps just adjust the throttle curve a little. You should be able to drop to an 11 or 12t pinion with no issues though. 11t may require a little motor plate grinding to get proper gear mesh, I have never run under 12t on an ax10, but usually run 16/87 with a 35t on 3s I like my wheel speed!
11-30-2010, 02:34 PM | #3 |
Pebble Pounder Join Date: Oct 2010 Location: florida
I currently still run the 14/87 gears and a 55 turn motor i tuned on a 3s lipo. I really like 55 turn motors and get about 6,500 rpm outta them. You could retard the timing a little and try it, that should help. |
11-30-2010, 03:54 PM | #4 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
wheel speed is a good thing IMO
11-30-2010, 04:20 PM | #5 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Use the same spur and get a 12T pinion. It will still have good wheel speed and even more torque. When you get down into 10-12T pinion you should get a longer one, so the pinion set screw does not get into the spur.
11-30-2010, 10:06 PM | #6 |
| Thanks for the advice. I did some experimenting today. I ran 12t & 14t pinions and there is a HUGE difference. 12t with 3s lipo really slowed it down. The 14t is MUCH quicker and I need that extra wheel spin to get out of a rock and hard place at times. The 14t is also needed to jump gaps if you know what I mean. Think I'll try a 16t pinion tomorrow.
