Thread: Need Help with VP Dig Assembly
Old 12-29-2010, 07:46 PM   #1
Exclamation Need Help with VP Dig Assembly
Hey just got my VP Dig from RPP today and I am looking at the instuctions and its all GREEK to me, any tips or tread links that might help would be great!! Thanks!!
CmdrZod is offline   Reply With Quote
Old 12-29-2010, 07:50 PM   #2
What do you need help with?
when installing mine I needed to press one of the bearings onto the supplied output shafts.
DioptricStraw is offline   Reply With Quote
Old 12-29-2010, 07:57 PM   #3
More so looking for a starting point, and any tips in the assembly process to make it easier, like if it need some sort of gear lube, that kind of stuff.
Old 12-29-2010, 08:57 PM   #4
You will want to lube up the internal parts and put a dab of loctite on that tiny ass screw that holds the drive dogs. They really should include a small allen wrench with this thing for that screw. I didn't have anything that would fit it and had to use a little flat head. Other than that I'd say it bolts right up to your tranny.
Aggie01 is offline   Reply With Quote
Old 12-29-2010, 09:03 PM   #5
Start by disassembling your tranny, replace the dogs, it uses a 1.3mm driver. lube up the internal gears in the tranny and in the dig.when you go to bolt everything back up use the new screws. last thing is the servo bracket and servo along with the linkage. I use a servo saver on my dig unit
VP Hurst Dig by DioptricStraw, on Flickr
Its a little hard to see but there is mine.
Old 12-29-2010, 09:16 PM   #6
Well I think I got it, Just have to put the servo bracket on and I should be good to go Thanks for the tips!!!
Old 12-29-2010, 09:17 PM   #7
and you'll need an iceberg sticker to really make it work good.
Wasp26Jim is offline   Reply With Quote
