Thread: GC-3A Budget Build
Old 01-04-2011, 05:34 PM   #1
Default GC-3A Budget Build
Figured I'd make a thread as well...
I wanted to build a comp rig on a budget, so with the help of a few members here I was able to come up with something that should work.
- GC-3A (new)
- Novak Goat 2S (had it)
- Novak 18.5T (had it)
- Hobbico CS170 steering servo (had it)
- Spektrum Z270 dig servo (had it)
- Spektrum RX (had it)
- AX-10 tranny w/ upgraded gears (had it)
- used DNA/VF dig (cheap!)
- SCX-10 front axle from the 4Runner(swapped with other one I had)
- new rear axle housing w/ old gears (cheap)
- Evader ST 4" aluminum shocks w/ cap mod, yellow springs (~$40)
- Losi gold springs ($10)
- unknown 2.2 Vanquish wheels, full set of weights (cheap!)
- white Rovers ($12/pair)
- Axial XC-1 body (cheap)
I think that's about it. I came out pretty good on this one.
Only pic I have, for now...
(had rock claws at the time)
92PathSE is offline   Reply With Quote
Old 01-05-2011, 12:46 AM   #2
Looks good, sounds like you got some good parts on the cheap. Should get ya started anyways.
LIKES2CRAWL is offline   Reply With Quote
Old 01-05-2011, 11:54 AM   #3
Started? As soon as I get the gold springs in, I'm done buying parts. lol
Although I'd really like to have a greater steering angle...
And the drivetrain is really sloppy...
And these wheels are a little too wide...
edit: nevermind about the flat spots...got that sorted
Old 01-05-2011, 12:02 PM   #4
Awesome chassis, just got mine and I love it! Try the overdrive front/underdrive rear gear combo, it'll make a big difference in turning radius.
TrailDawg362 is offline   Reply With Quote
Old 01-05-2011, 05:39 PM   #5
That thing looks great 92PathSE. Nice job!
snipe1 is offline   Reply With Quote
Old 01-05-2011, 06:00 PM   #6
Default Nice build!
Great build on the cheap.. looking to do the same thing myself, thanks for the ideas and congrats...
thkov is offline   Reply With Quote
Old 01-05-2011, 06:33 PM   #7
looks good , I agree on the under and overdrives that would be my next purchase ,you will see a huge improvement
Gatekeeper is offline   Reply With Quote
Old 01-05-2011, 08:39 PM   #8
Nice man.
GRIMGREG is offline   Reply With Quote
Old 01-06-2011, 07:23 AM   #9
Over/under does sound like a good idea.
Anybody know off the top of their head if the AX-10 and SCX-10 come with the same ratio R&Ps? I didn't think to check.
Old 01-06-2011, 08:16 AM   #10
Yes they do. Enjoy the rig,The Gatekeeper designs chassis are the only way to roll.
Cave Dave is offline   Reply With Quote
Old 01-06-2011, 06:38 PM   #11
Golds in, Rovers on
Those springs made a huge difference. I set them to about 2.25" under the skid. Tomorrow will be the real test.
Thanks for the compliments.
Old 01-06-2011, 06:57 PM   #12
Did you have the chance to move the links on the chassis?
Speedracer19 is offline   Reply With Quote
Old 01-07-2011, 07:32 AM   #13
Yeah, but I couldn't tell a difference on the stuff at home. I'm going to try it out at Flat Rock this afternoon.
Old 01-07-2011, 09:02 AM   #14
Was wondering if you have a part number for the losi gold springs...Are they for 4" shocks or 3.5" . Any help would be appreciated
CairoCrawler is offline   Reply With Quote
Old 01-07-2011, 05:54 PM   #15
I do.
LOSA5144 - 2.75", 1.4 Rate (in/lbs?)
I've got 4" shocks. The spring falls out of the cup when the adjuster is at the lowest point. So far I haven't lost a cup. They'll work on 3.5s too, and I assume they will always make contact with the cups so they won't fall off.
Old 01-07-2011, 05:56 PM   #16
It's a lot better. Moving those links, tires, springs...major improvement.
Photos in a few...
Old 01-07-2011, 07:14 PM   #17
This is in the horseshoe on the far right. It ran right up the spot where I was having trouble last week. It still tries to roll, but it's far better.
Another gate from last week. Walks this now.
Close to the same spot. I think Kinson made it up this somehow. I burned nearly an entire pack trying to figure it out. Didn't happen.
Just a photo...
I'm going to make or buy some new foams soon. The stock foams are too small/stiff. Lots of wheel hop becuse of the flat spots.
Old 01-07-2011, 07:50 PM   #18
Take a look at some Nova Double Deuce foams.
Wicked Klown is offline   Reply With Quote
Old 01-15-2011, 07:48 PM   #19
I came up with some foams. I only had enough to get the rear tires set up, but it was a big improvment.
But then...Kablammo!
Goat blew up and took my only battery with it. Doh!
Old 01-16-2011, 03:09 PM   #20
Sucks. Now what?
cwettstain is offline   Reply With Quote
