Thread: my ax 10
Old 01-11-2011, 03:18 PM   #1
Default my ax 10
Okay guys I got this used and would like some input. I have the stock chassis, proline eight shooter bead locks, panther leaperd tires, hot racing dig, 4 link front and rear and 55t novak terra claw motor. I don't comp with it but I may later. I will link some pics.
http://i1215.photobucket.com/albums/...1-11170422.jpg
http://i1215.photobucket.com/albums/...1-11170521.jpg
http://i1215.photobucket.com/albums/...1-11170541.jpg
goose ae is offline   Reply With Quote
Old 01-11-2011, 03:31 PM   #2
Not bad. Myself I would see about getting different shock & springs, going lipo, getting a 35t or 45t motor. Also see about getting a delrin skid plate that moves the lower links inward more.
Wicked Klown is offline   Reply With Quote
Old 01-11-2011, 03:37 PM   #3
What kind of shocks and springs should I look for.
Old 01-11-2011, 03:49 PM   #4
Alot of people seem to use Big Bores.
Old 01-11-2011, 03:51 PM   #5
I saw that. Would you run them with a really soft spring all around or just up front. I'm new to all this
Old 01-11-2011, 03:54 PM   #6
When I first bought my used AX10 it came with Losi 4" rock crawlers with soft up front and little firmer in the rear. I later changed chassis and went with a shorter shock with Losi 2.75" white springs in the front and Losi Yellows in the rear. Later I plan to change to Traxxas GTRs with 0.7 Jato spring on all four corners.
Old 01-11-2011, 04:01 PM   #7
Thanks man. I will check the forums for more on the shocks.
