01-13-2011, 09:34 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
| Axial c hubs and VP knuckles!
I want to know if anybody has had a problem with this set up. When I went to bolt everything up the VP knuckles wont turn free like they did when I just had the plastic parts on. I can't seem to figure it out. The parts im using are the VP regular high steer knuckles and axial aluminum c hubs. Your help will be much appreciated. Thanks Marauder!
01-13-2011, 09:41 PM | #2 | |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
01-13-2011, 09:46 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
That is exactly the same set up I have on my rig but with a LD BTA steering set up and they work just fine, No binding at all, do you have both of the little shoulder bushings in the knuckles on both sides? Mine does not bind at all.
01-13-2011, 09:48 PM | #4 |
Yeah Im using the metal flanged pipe but I din't but them in thru the top.
01-13-2011, 10:00 PM | #5 |
The flanged pipe should be longer than the hole in your knuckles. So the screw should ride on the flanged pipe, but if you run it the other way with washers in between it takes any vertical slop out of the knuckles as well.
01-13-2011, 10:01 PM | #6 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
The flange pipes get inserted between the hubs and the knuckles. Also, if you are having binding, it is possible to be your axle shafts. Now, if you do not have them installed yet....nevermind. Casey |
01-13-2011, 10:09 PM | #7 |
KC the axle shafts are installed but I don't understand how that could be a factor? Im in over my head with this one. Ahhhhhhhh!
01-13-2011, 10:11 PM | #8 |
If you can post up some pics so we can see what you have going on... |
01-13-2011, 10:13 PM | #9 | |
Just have a play with them...you should figure it out. FYI...I only run VP zero ackermann knuckles with Axial aluminum C hubs. | |
01-13-2011, 10:39 PM | #10 |
Pebble Pounder Join Date: Nov 2007 Location: Canada
Your issue is 100% in the outdrive cups. Axial has 2 different types of outputs, one is physically slotter deeper then the other(you need the deeper one), both are the same part numbers though. Axial and I went through this. They replaced both my axle c's and my outdrives. The outdrives was the cure upon lots of trial and error. I dont have a picture handy. Sorry! But this is your problem FOR SURE. |
01-13-2011, 10:45 PM | #11 |
So your are saying I will need to replace the out drive cups in the front? And if they both have the same part nunmber haw do I know witch one to get. This gets better by the minute!
01-13-2011, 11:00 PM | #12 |
Ok Isone, I think you are very right on this because when I loosen up the set screws on the c hubs it releases the tension on the drive cup and the knuckle turns easy. How do I get the right drive cups now?
01-13-2011, 11:06 PM | #13 |
Or, just switch to CVDs. I use 3Racing with gunnar pins. I have not broken one yet.
01-13-2011, 11:10 PM | #14 |
CVDs do you mean the dog bones?
01-13-2011, 11:21 PM | #15 |
01-13-2011, 11:27 PM | #16 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
I"m with brian! I get it a lot and the washer between the top hat bushing and C fixes it every time!
01-13-2011, 11:39 PM | #17 |
PipeDreams I did do that already and it din't fix the problem. It just seams that the drive cup should be a little longer.
01-13-2011, 11:52 PM | #18 |
OK cool!
01-14-2011, 06:06 AM | #19 |
Newbie Join Date: Dec 2010 Location: Gold Canyon
When I installed my Axial BTA kit, I had this issue with SP Racing C's. I put a Losi thin washer I had between the bottom insert and the C, and the problem went away. Chris
01-14-2011, 07:38 AM | #20 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
| Have you checked to be sure you are not threading the set screws in too far? That may be the cause.
