Thread: Stripped C hub hole on axle tube
Old 01-14-2011, 09:07 AM   #1
Default Stripped C hub hole on axle tube
I seem to have stripped the plastic hole on my axle tube where the C hub mounts, I have tried using a coarse thread machine screw but it no worky. I suppose I could move up to a slightly larger screw, but is there a better option? I'm not real keen on counting on the plastic axle tube to keep things tight, I'm thinking some toobs might be the solution since it would give me some metal to fasten to as well as the strength ascpect they were designed for. Until then, any suggestions?
day215 is offline   Reply With Quote
Old 01-14-2011, 09:14 AM   #2
try blue loctite and/or CA glue on your screw or a bigger 4mm screw might fit.
Cases are only $10 or so? I might not be a bad idea to just get new ones.
helhedded is offline   Reply With Quote
Old 01-14-2011, 10:05 AM   #3
I did the same thing recently on my axle cases. Larger screws would work as a bandaid. New axle cases would solve the problem. Or... you could get toobs and have rock-solid axles. I'll be running toobs in all my ax10 axles (at least the fronts) from now on.
version_three is offline   Reply With Quote
Old 01-14-2011, 02:12 PM   #4
Bigger screws did help
Have'm 3 overall.
shizzz is offline   Reply With Quote
Old 01-14-2011, 03:07 PM   #5
You need the Gunner beef tubes! They work great. Look in the vender section. Kcjones is selling them. It will be stronger and you dont need to buy a new axle housing.
92LILREDYJ is offline   Reply With Quote
Old 01-14-2011, 03:29 PM   #6
Yeah, Gunnar toobs are next on the list for sure. I had some larger coarse thread screws that I cut down to size, there nice and tight now, it will work for awhile.
Old 01-14-2011, 03:47 PM   #7
Yeah I did that too, they will work for a while. Just remember that is a weak point. What C's do you have?
Old 01-14-2011, 04:55 PM   #8
Venom aluminum, eBay 5 bucks. Not the best but better than stock.
Old 01-14-2011, 05:01 PM   #9
M3 heli-coil is how I fixed my stripped out holes.
BigSki is offline   Reply With Quote
Old 01-14-2011, 05:30 PM   #10
Do not use blue loc-tite. It melts plastic.
Super glue is a temp fix (comp situation, no spares)
Only 3 perm fixes, new housings (they are like $5-10), change to larger dia screws, or put some toobs in it.
WIDELOAD is offline   Reply With Quote
