01-20-2011, 02:38 PM | #21 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
The stock chassis is pretty lousy. The stock skid can be modified to inboard the lower links, but you still have a ridiculously wide chassis with poor upper link mounting options and horrible location for shock mounts. Most of the popular aftermarket chassis are a dramatic improvement over stock. My advice is to find one that has a few very detailed build threads on here that you can emulate. Several people have shared their setups and copying these gives a great starting point for your build. Now, that said, what works for me may not be perfect for you, but I can guarantee if you copied my setup, you'd have a rig that would run circles around what you're currently used to. Use a build as a starting point and go from there. (that reminds me. I forgot that I haven't posted a build thread on my Axial...oops) I'm currently running my AX10 as a Sportsman class rig on a CDW Chump chassis. I really like it, but if I was to buy a new one, it would probable be the T1e chassis. My 2nd choice would be the BWD wedge. |
01-20-2011, 03:09 PM | #22 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
I started with a stock chassis and moved on to a BWD SlingShot chassis. So far I love this chassis just need to upgrade my shocks to some GTRs with Jato 0.7 springs.
01-20-2011, 05:04 PM | #23 |
| Mini-T springs fit nicely internally in the GTR's. You don't have to worry about the tires getting into the springs and you can get some softer spring rates than you will with the Jato springs.
01-20-2011, 05:59 PM | #24 |
You'd be amazed at the lines possible with a non-dig AX10 based crawler. My Sportsman does some things as well, if not better than my berg.
01-20-2011, 06:25 PM | #25 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| Ive NEVER touched an MOA or Dig, all I got is Underdriven rear and that's it for "aids" to my car. ALL I can say is a properly setup car and engineered chassis is amazing. I love it when Shafty's beat MOA's on courses, its a great feeling |
01-20-2011, 08:47 PM | #26 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Beating a dead horse here but the only thing left on my shafty from my stock setup is the rear axles, the tranny, and the front axle locker and pinion. All of this happened because I built a crawler course outside the house and would drive for 5 minutes find a weakness and tune for 2 nights to make that less of a weakness. That eventually lead what I just described above. For your sake I wish the fastback was still around but if you want my ff4 I will sell that to you.
01-20-2011, 10:02 PM | #27 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
01-20-2011, 10:31 PM | #28 | |
Hey thanks I'll have to look in to those. Reason I went with the Jatos as thats whatever one else was using. I already have the springs just need the shock. Might have to get the mini-ts tho. Edit: Wouldn't that make a droop set-up tho? Are you talking about on the inside of the shock or like how guys run the big bore shocks? Last edited by Wicked Klown; 01-21-2011 at 12:50 AM. | |
01-20-2011, 11:00 PM | #29 |
01-21-2011, 12:25 AM | #30 |
Here's what a good chassis can do on an AX10 with no DIG or wheel weights http://www.youtube.com/watch?v=5OtFO...layer_embedded |
01-21-2011, 06:54 AM | #31 | |
When buying shocks, the Revo 3.3 GTRs are worth the extra $$$. The Ti- Nitride shafts seem alot stronger. | |
01-21-2011, 09:01 AM | #32 | |
01-22-2011, 05:30 PM | #33 |
Rock Stacker Join Date: Mar 2009 Location: canada
Wowsers. Thanks to everyones response, definitely gave me lots to think about.
02-01-2011, 03:23 PM | #34 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
I couldn't agree more with you. You can take the sock chassis a long way - it's only when other people set the lines that an aftermatket chassis becomes a necessity - immediately! The biggest problem with the decision is which one, not whether to, as you'll already have reached that point if you've tuned the stock sereral times over. |
02-01-2011, 03:27 PM | #35 |
Any idea when the viper will appear?
02-01-2011, 09:51 PM | #36 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
The viper is due out some time this month. There is a thread dedicated to that chassis in the xr10 section.
