01-20-2011, 08:03 PM | #1 |
Newbie Join Date: Nov 2010 Location: bonne terre
| Axial bta pic please
Hey guys can someone please post a few pics for me of there axial bta drag link set up please. And my c hubs look like they can be setup straight or in a bit of tilt, what's the best setup for turning radius? Thanks and what's the best servo arm length when using the axial bta
01-20-2011, 08:39 PM | #2 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I use only Vanquish zero Ackermann knuckles...so I had to make my own tie rod. Last edited by KC_JoNeS; 01-20-2011 at 08:44 PM. |
01-20-2011, 08:40 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
01-20-2011, 11:08 PM | #4 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
Do a search for DickT's UGC Fastback. He used to run an Axial BTA with a cut up VP plate for 4 link.
01-20-2011, 11:32 PM | #5 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
In my build (link in signature) you can have a look.. I have a lot of pics of the steering. Custom top plate with vp 0 ackerman knuckles! Do you want a 4 link or factory 3 link? You want the pinion to point as close to the trans output as possible while keeping the steering leaned back as much as you can... It's tough to do with out rotating thing even more and doing custom stuff. Servo horn depends what axles you're using and your setup.
01-21-2011, 12:31 PM | #6 |
all of my steering problems are from a busted servo. i guess after i put on my mayhem phatty rims the ppp servo that is on my rig just gave out. the metal gear the horn bolts to is pulling out of the servo casing. now its time for a new servo, any suggestions would be greatly appreciated. i am running stock axial locked axles, axial bta and low cg axial plate. i will be running a robitronic arm and need to know if i should get a 16mm short arm or the 20mm normal arm. thanks guys.
01-21-2011, 12:53 PM | #7 |
Newbie Join Date: Jan 2011 Location: Pirate4x4.com/Greenwood, AR
I bought the Axial kit. The tie rod rubs the upper link where it screws onto the top of the housing. It doesn't affect my steering any, but it doesn't look clean. :( When I 4 link it I will make sure to fix this issue, as I'm not a fan of parts rubbing each other. |
01-21-2011, 11:20 PM | #8 | |
01-22-2011, 12:49 AM | #9 |
The hobbico hs170 is a good servo for the money http://www.rcplanet.com/Hobbico_TG_S...p/HCAM0316.htm |
01-22-2011, 06:23 AM | #10 |
Newbie Join Date: Dec 2010 Location: Gold Canyon
| Drag Link I added a nut to the ball stud on the servo arm after this picture. Chris Last edited by snoking; 01-22-2011 at 06:29 AM. |
01-22-2011, 07:14 PM | #11 |
I just ordered a hittec servo. I was wondering how to up my cc bec to 7.4 or higher since I'm ordering a 8 or 9 cell elite 1500 crawler pack, I havent decided yet on which cell count.
01-22-2011, 07:46 PM | #12 |
Quarry Creeper Join Date: Jun 2009 Location: ...
you need the castle link and a computer |
01-22-2011, 07:51 PM | #13 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
Remember before you go an up the voltage make sure your servo can handle it.
01-22-2011, 08:00 PM | #14 |
Pebble Pounder Join Date: Oct 2010 Location: florida
Which hitec servo did you purchase?
01-22-2011, 08:15 PM | #15 |
| I run a longer M3 up through the bottom of the knuckle, and then add a nut on top. I found that the steering force was enough to start loosening the M3 as it is in this picture. Then it starts to wallow out the threaded portion of the knuckle. Something to keep an eye on.
01-22-2011, 08:54 PM | #16 | |
01-22-2011, 09:07 PM | #17 |
I got a hittec hs7954sh. I need to raise my voltage up on my cc bec to 7.4. I guess the hunts on for a cc castle link.
01-22-2011, 09:11 PM | #18 |
You can get the CC link at Amainhobbies, Stormerhobbies, Towerhobbies and CKRC. Top view Bottom view |
