01-30-2011, 10:37 PM | #1 |
Pebble Pounder Join Date: Aug 2006 Location: Raleigh NC
| driveshaft/axle yoke problems
Hey guys, Trying to get my axial running and I am having a problem with the driveshaft slipping on the pinion yoke of the axle. I've tightened the set screw as much as I can. Is there any way to fix this or is there an upgrade? Zack |
01-30-2011, 10:48 PM | #2 |
Newbie Join Date: Nov 2010 Location: burlington
| axle
just a ?? are you sure you have the set screw hitting the flat part of the shaft before you tighten it ?
01-30-2011, 10:49 PM | #3 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
You can/should add a second set screw. You could also get some steel yokes.
01-30-2011, 11:00 PM | #4 |
yep, definitely got it hitting the flat spot on axle and I have the second screw on the other side. They are the plastic yokes and I don't want to strip them by over-tightening. I could also upgrade all the shafts to either MIPs or something else? I was also thinking about drilling a hole through the yoke and then running a steel pin through it. Don't know if this would work or if it could eventually weaken the yoke itself. |
01-30-2011, 11:07 PM | #5 |
Just get some steel yokes.
01-30-2011, 11:26 PM | #6 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Steel yolks will work until you want to upgrade to something stronger. Stay away from 3 racing and intergy shafts, they are useless. when you do upgrade have a look at the junfac shafts. I use them in my comp axial and rate them very highly. MIP's are great too but they are a lot bigger and heavier than the junfac's. |
01-31-2011, 10:57 AM | #7 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Steel yokes, blue locktite, and double set screws.
01-31-2011, 11:13 AM | #8 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
I had a similar issue with my steel yokes, a Guy at my LHS said not to use double set screws. I tapped out one of the holes to 4mm and installed a single 4mm traxxas set scree. Holds it nice and tight now, steel yokes would be the first step though.
01-31-2011, 12:27 PM | #9 |
well, looks like I'm going to order some Junfac driveshafts. Not too expensive at $35 for both front and rear and I should have a solid drivetrain. I'm assuming that with the steel yokes you can really torque down on those screws so it will hold tight. That and with some blue loctite, I don't see these things going anywhere. Thanks guys, I will update my build thread in a bit. Zack |
01-31-2011, 01:34 PM | #10 |
| I'm not sure why the guy at your LHS would tell you not to use 2 set screws? But, I've been runnung steel yokes with 2 set screws with my plastic shafts for well over 3 years now with 0 issues.
01-31-2011, 01:54 PM | #11 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
I had the same problem, changed the yokes and haven't had a problem since. Junk the stock shafts as they're useless. I put 3racing ones one, and after reading up after the event bought some Junfac ones for when they fail. That was a good few battery packs ago and they ain't gone yet. I do keep them well lubed though. The blue locktite is essential - I bought my AX10 as an RTC and non of the set screws had been locked in chemically - needless to say I one of them first time out, came home and rebuilt the whole rig (a process that has been repeated man y times since)!
01-31-2011, 11:54 PM | #12 |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
I have the same problem with my axial scorpion so I bought a hole new rear end and added Beef tubes There some good tips when I opened the old rear end I couldn't find anything wrong with it. |
02-01-2011, 12:15 AM | #13 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Plenty of room to go 4mm on the Junfac's: |
02-01-2011, 12:38 AM | #14 |
Rock Stacker Join Date: Jan 2011 Location: santa clarita,CA
02-01-2011, 02:36 PM | #15 |
Well, I ordered the Junfacs, they shipped from Korea today. I definitly want to put 4mm set screws in. Is it just a matter of running a 4mm tap in there or will I need to drill it out a little bit? Zack |
02-01-2011, 03:12 PM | #16 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
I run the junfac shafts on my rig. The set screws that come with the shafts have knurling on the tips to help prevent them from comming undone
02-01-2011, 08:05 PM | #17 |
