Thread: "SNAP" went the front output....
Old 02-06-2011, 01:19 PM   #1
Default "SNAP" went the front output....
Playing today and "SNAP" the front Tcase output gave up the goat.......Tcase gears were stock, but look at the center of the output and you will notice that it was hollow? What kind of sh$t is this?
So it is now time for anouther set of gears, who's making the best set of Tcase gears? I'm not price shopping here I'll pay for what is good so that way I don't have to cut my wheelin trips short again.
Looking at the plastic Tcase case that looks like the next thing to go when I upgrade the gears, should I upgrade that? who make the best case? again I'm not looking to price shop here either. Is there anything else in there I need to upgrade while I'm in there I don't want to go into that thing more than one time......Heath.
newmexicocrawler is offline   Reply With Quote
Old 02-06-2011, 01:36 PM   #2
Heres a set of steel outputs for $11. Might as well upgrade the case and gears while you have it torn apart.
http://www.ckrccrawlers.com/ax30544-...on-p-2702.html
NMLJ is offline   Reply With Quote
Old 02-06-2011, 01:37 PM   #3
RRP one piece output spool.
2JSC is offline   Reply With Quote
Old 02-06-2011, 01:45 PM   #4
Who makes good ones........?
Old 02-06-2011, 02:02 PM   #5
The VP case is really nice.
http://www.vanquishproducts.com/vanq...n-housi10.html
DioptricStraw is offline   Reply With Quote
Old 02-06-2011, 02:11 PM   #6
This is what I'mm looking for, info I didn't know about I only knew of the HR and CKRC cases......Thanks for the info.
Does VP have a case with built in dig?
Old 02-06-2011, 02:21 PM   #7
Yashua
CREEPERBOB's Avatar
HHMMMMMMMMM,,,,,,,,,,,,,,,,,, CREEPER TRANNYS DO'NT BREAK,
NO BUT SERIOUSLY!
CREEPERBOB is offline   Reply With Quote
Old 02-06-2011, 03:20 PM   #8
No idea what I'm doing
If you don't have a dig yet, I'd go for the Vanquish dig since it comes with steel outputs.
If you don't want a dig, check out the Robinson outdrive gear.
The idler gear is another weak spot, so while you have it apart, drop in a Robinson idler too.
Basically, make your spur the weak link in your transmission...keep it plastic. That way if something goes, it's easy to replace.
If you go with a Vanquish case and Robinson internals, you should be pretty bulletproof.
Good luck
C*H*U*D is offline   Reply With Quote
Old 02-06-2011, 05:22 PM   #9
Good luck
X2 on the VP case and RR gears. VP has not had any black cases in for months, but the silver is in stock.
Aggie01 is offline   Reply With Quote
