Thread: issues with Ball ends
Old 03-06-2011, 09:17 AM   #1
Default issues with Ball ends
hi all 1st post
learning and using my modded ax10 hard but...........
getting bored now with breaking the plastic cranked ball ends
whats a good replacement or does the damage just get transfered if they are stronger
tia
milkyax10 is offline   Reply With Quote
Old 03-06-2011, 09:23 AM   #2
Suck it up!
Duuuuuuuude's Avatar
Traxxas ball ends are stronger. If you want to keep all of your original links and rods, the standard Traxxas ends will fit fine. If you want to upgrade to aftermarket links and rods, go with the Jato or Revo ends which are larger and stronger yet.
Duuuuuuuude is offline   Reply With Quote
Old 03-06-2011, 09:24 AM   #3
Tossin' Salad
You can get away with using those ball ends for upper links, but that is about it. For lower links, it is best to switch to 4mm Traxxas ends. You search it out, and you will find them.
Casey
KC_JoNeS is offline   Reply With Quote
Old 03-06-2011, 09:37 AM   #4
i use the bigger dubro rod ends that fit 6-32 threads and never had one break yet........bob
bob1961 is offline   Reply With Quote
Old 03-06-2011, 09:55 AM   #5
Location: You will never find a more wretched hive of scum and villainy
i run 5468 traxxas ends and they are beef you can use the stock axial balls and 3mm set screws with them as well
DeweyCJ5 is offline   Reply With Quote
Old 03-06-2011, 10:35 AM   #6
cheers all traxxas it looks like for now thanks for the replies
Old 03-06-2011, 10:40 AM   #7
ordered £3 for 6 ebay ftw ....;)
Old 03-06-2011, 10:51 AM   #8
I use both Revo and Jato ends and they hold up so much better than Axial's. Ends are only as good as the plastic eyelet holding them in place...after a while all ends need to be replaced anyway.
Not sure about RC4WD's steel ends. Can someone chime in on those?
alexchen86 is offline   Reply With Quote
Old 03-06-2011, 12:31 PM   #9
Iam still running the factory rod ends and have yet to see a problem with them but I think when one breaks I will change them over to the traxxas one cause they are stonger
9700trevor is offline   Reply With Quote
Old 03-06-2011, 09:53 PM   #10
Just one thing to consider. Revo and Jato rod ends are the best imo, but they use 4mm hardware. So, depending on what you are using for links you may have to make some new links.
Aggie01 is offline   Reply With Quote
Old 03-07-2011, 09:49 AM   #11
Not only stronger, but they pivot a lot more freely than the Axial plastics.
GRIMGREG is offline   Reply With Quote
Old 03-07-2011, 06:38 PM   #12
Natedog's Avatar
Those are 3mm for the rod, not 4mm? Are you sure?
Old 03-07-2011, 07:14 PM   #13
yes, i am running stock 3mm set screws and ball ends in them... i just built my new rig with those on Thursday of last week
Old 03-08-2011, 10:39 AM   #14
had my traxxas ball ends today and fitted them up with a set of losi rock claws .....what a transformation over the hammers no link breakages.....very happy
cheers all for your help
Old 03-08-2011, 12:39 PM   #15
Natedog's Avatar
Thanks!
