02-18-2011, 10:07 PM | #1 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
| RockMafia's FROG HAS SPLATTERED NOW FASTBACK II
hi guys trying a bodiless chassis for my sportsman rig its a frogger chassis from KC_JoNeS in china so I called this one FROG-SPLATTER it will be out and about for the march comp so here's some pic so for cheers Rino [IMG]http://i818.photobucket.com/albums/zz105/rino903/8e583250.jpg[/IMG Last edited by RockMafia; 10-13-2011 at 12:32 AM. |
02-18-2011, 10:32 PM | #2 |
Quarry Creeper Join Date: Jun 2009 Location: l.a.
niiice im diggin the chassis (would you send me the info to get one and how much) .looks really good raked back like that.the panels you made and how they re mounted behind add to the looks .killer
02-18-2011, 10:35 PM | #3 | |
Quarry Creeper Join Date: Oct 2010 Location: So. Cal
02-18-2011, 10:38 PM | #4 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Nice one Gaspare. Keep up the progress! EDIT: Helping you with that last photo Casey Last edited by KC_JoNeS; 02-18-2011 at 10:56 PM. |
02-18-2011, 11:05 PM | #5 |
Rock Stacker Join Date: Jan 2011 Location: Sundre, Alberta
sweet paint job!
02-19-2011, 03:31 AM | #6 |
Thanks guys happy with the job so far , thanks Casey for the picture fixup Cheer Gaspare(Rino) |
02-19-2011, 12:00 PM | #7 |
Pebble Pounder Join Date: Jan 2011 Location: Mtz
Looks great, the paint job is kind of different, but I really like it. Not something I have seen to much on a crawler. I know that Kc Jones is trying to get rid of the frogger chassis, and for the price, I might just have to get one. Looking forward to seeing the finish product.
02-19-2011, 02:21 PM | #8 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
Looks good Gaspare - waiting for mine - everything's been stripped down today. What have you used for the panels - is it a plastic card or lexan? Also, are those standrd axial bent links in the pak or have you had some made up to length? be good if those fot s I've got loads of 'em.
02-19-2011, 10:16 PM | #9 | |
02-20-2011, 04:51 AM | #10 | |
Yeah, I 've got a mix of copies and Axial ones - think minme are 3Racing but they're OK - not bent any and they don't seem to scratch up any worse than the Axial ones. | |
02-20-2011, 03:16 PM | #11 |
RockMafia Found plenty of lexan sheet on ebay. How thick did you go -2mm? |
02-20-2011, 06:26 PM | #12 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
Hey, I used a grinding mask clear outer (will remove the over film once painted) its 1mm thick and fairly stiff. Works well. Nice work Rock, diggin' the blue. |
02-20-2011, 11:41 PM | #13 |
Hi guys small update got a little done installed tranny(running a teambr00d 45t motor) ,razors , lower bent links and the rear end cheers Gaspare (Rino) |
02-20-2011, 11:45 PM | #14 | |
02-20-2011, 11:47 PM | #15 |
Lookin' good mate! Casey |
02-21-2011, 05:21 AM | #16 |
Thanks, 0.030 then, just less than 1mm. 1mm is easy enough to get hold of.
02-22-2011, 09:35 PM | #17 |
Hi again guys another update finished the assembly Ive just got the electronics to put back in cheers Rino ps (Hey Casey does look like the chassis is siting right) |
02-22-2011, 09:40 PM | #18 | |
Get your steering dialed, capture some video, and post it up. Casey | |
02-22-2011, 09:45 PM | #19 |
cheers mate will do
02-22-2011, 09:47 PM | #20 |
Also, the only thing I see that is questionable is your rear lower links. I would probably try to replace that skid plate in favor of one that triangulated your lowers better. I love using the Razors in the rear, and then triangulate the lowers a rediculous amount. I see no TT on my comp frogger because of this. Casey |
