Thread: tranny output upgrade
Old 02-27-2011, 04:09 PM   #1
Default tranny output upgrade
Hey guys ive been having a problem with breaking the outputs on the tranny of my scaler. I was thinking of upgrading my sportsman and scaler at the same time. I was looking at the robinson racing one piece ( http://www.ckrccrawlers.com/robinson...10-p-2414.html ) and that looks great for the sportsman but for the scaler i was thinking of putting a dig on it at some point so the robinson one wouldnt work. I see the steel outputs they are like half the price but idk if those are an actual upgrade or just a cheap replacement.( http://www.ckrccrawlers.com/ax30544-...on-p-2702.html )
I am running these on both rigs now http://www.ckrccrawlers.com/ax30404-...t-2-p-811.html
mindless is offline   Reply With Quote
Old 02-27-2011, 04:35 PM   #2
If you are planning to go Dig, the axial steel's are the way to go.
The ones you listed (Ax30544) are the deffinate upgrade as they are actually steel, not aluminium.
I have also used 3Racing stainless steel ones without an issue.
WIDELOAD is offline   Reply With Quote
Old 02-27-2011, 05:10 PM   #3
cool thank you much do you know if the steel ones are solid and not hollow like the aluminum ones??
Old 02-27-2011, 05:36 PM   #4
You can still use the Roberson one piece gear and then use one of these..
It's the Eritex DIG, the only dig that does not need trans mods....Heath.
newmexicocrawler is offline   Reply With Quote
Old 02-27-2011, 05:42 PM   #5
The robinson one peice diff is the best you can get for the sportsman.
For the scaler with dig: I used the Robinson Racing HD aluminum output gear with the DNA dig HD outputs. http://www.rpphobby.com/ProductDetai...ctCode=RRP1540
You should also upgrade the idle gear to robinson HD.
TedBull is offline   Reply With Quote
Old 02-27-2011, 06:24 PM   #6
i already have a hr dig laying around that i would use so trying to work around that, ill prob pick up a set of steel and a robinson spool style one. Thanks for the help guys
Old 02-27-2011, 08:21 PM   #7
Try to Bend it
Highlucks's Avatar
Another Vote for the RR one piece gear. Such a solid bit of gear. good luck breaking it.
Another one to look at might be the new crawler innovations out drives that Eddie has just released.
Highlucks is offline   Reply With Quote
Old 02-27-2011, 10:08 PM   #8
I just installed a set of 3 racing stainless steel outdrives tonight. I snapped one of the stock aluminum ones last week. The way I look at it is that anything steel has got to be better than the stock aluminum ones.
Chevdog is offline   Reply With Quote
Old 02-27-2011, 10:45 PM   #9
www.team3sixrc.com
If your looking for good ones. BOWTIE sells some great ones for a better price and yes they are steel.
You can also go to TheToyz.com and he sells some nice stainless that I have had NO issues with.
team3six is offline   Reply With Quote
Old 03-01-2011, 03:17 PM   #10
I joined the Band!
Does anyone make ones that are drilled out?? Would be nice...I could run my Maxx Shafts...
skullking is offline   Reply With Quote
Old 03-01-2011, 05:01 PM   #11
Yes, see below....
FWIW, I am running both the RR solid in my Pro truck and the 3R SS 2pce units in my Sportsman. Both are equally effective, although the RR unit is behind a Holmes Hobbies/3S combo....
Last edited by stewbaru; 03-01-2011 at 09:47 PM. Reason: Corrected by my brother VV
stewbaru is offline   Reply With Quote
Old 03-01-2011, 05:32 PM   #12
Try to Bend it
Highlucks's Avatar
Yep,
Click the pic.
