03-10-2011, 06:15 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: RI
| Ax 10 suspension question
Hello all,Im new to crawling,Im looking at AX90011 AX10 SCORPION "READY TO CRAWL" RTC, 2.4GHZ, DRAG BRAKE.Seems to have all the good parts metal servo,good contoller,spped control etc, but does the slipper clutch make it bouncy? Many of the videos look like is bounces vs grips the rock with its suspension? In person how does it do? It seems to be the number 1 recomendation at this price point. I am looking to try crawling with the kids and to have fun.Trying to stay around under $250. |
03-11-2011, 06:37 AM | #2 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
The slipper won't affect your grip. If you're new to the game then it will help protect your drivetrain - you're better off with it than without it. Check out the posts on here as there's lots on buying your first crawler - the AX10 is a good place to start - works well out of the box - especially for what you want. Support for it is excellent. The Losi Night Crawler is arguably more modern - it's quite different and needs more maintenance but equally good at what you want one for. If you buy an AX10 then buy the shrouds for the drive shafts at the same time and put them on BEFORE using it - this also ensures that you loctite the set screws back in (as opposed to relying on the factory. This way you'll not be frustrated if the shafts fail first time out! Everything else tends to work OK. Read the threads on upgrades once you're ready to take it further.
03-11-2011, 12:41 PM | #3 |
Dasher thanks for the advice.Where can I fing the driveshat shrouds? I loked at a few sites and search didnt turn up anything? |
03-11-2011, 12:51 PM | #4 |
Here you go....http://www.rpphobby.com/product_p/ax30501.htm |
03-11-2011, 01:49 PM | #5 |
Thanks!
03-19-2011, 04:27 AM | #6 |
Ordered the ax! Woohoo. Now. The wait |
03-19-2011, 07:17 AM | #7 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
I just got one also for a new build. You are going to want to get a Castle USB Link to hook up to the AE-2 ESC. The Drag Brake setting is supposed to come set at 100% but mine was at 50%, It was like having hardly any Drag Brake. The Castle Creations Link lets you hook the ESC up to a computer and adjust the Settings.
03-19-2011, 05:36 PM | #8 |
Newbie Join Date: Feb 2011 Location: Pembrey Wales U.K
nice choice you will love it |
03-20-2011, 05:26 PM | #9 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Some of those videos might be of it stock with unweighted wheels or tuned tire foams.
03-20-2011, 09:30 PM | #10 |
Newbie Join Date: Mar 2011 Location: california
| shrouds
where do u place those driveshaft retainers. can someone take a picv or show me. im lost thanks guys
03-20-2011, 11:46 PM | #11 |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
They go over the actual u-joint area.
03-21-2011, 12:39 AM | #12 | |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Ther answer and a picture is in the thread you started. driveshaft help please | |
