03-20-2011, 08:56 PM | #1 |
Newbie Join Date: Mar 2011 Location: Houston
| Spur Gear
I recently replaces my factory drive shafts after my last trip out crawling thanx to a tire trap, and my goat 3s system!! I went with Jun Fac they are working great maybe to great! Lol. Playin round the house today since drivetrain is beffed up now I stripped plastic spur gear. Any suggestions or experiences with a good replacement, or ideas of what may be next to give way? As always I appreciate the input.
03-21-2011, 01:43 AM | #2 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
You'll either learn to be light with your finger in a bind or you'll just break everything plastic...and I mean everything. So...you'll have a 15lb rig or you'll be a better driver? So your shafts and spur gear are all upgraded stuff now....next to go...outdrives, idler gear, outdrive gear. Hamma time. |
03-21-2011, 02:03 AM | #3 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Wow a 15lb rig, I don't think he is building a fully tubed scaler with steel panels and steel billet wheels. I still run a stock 48p 87T spur on one of my rigs, with junfac shafts and a 7 turn puller on 2S. It is standing up to the power well. You may have had a bad mesh between your pinion and spur causing it to fail sooner rather than later. If you do want to upgrade to some more beef. Robson Racing make a nice Titanium spur gear. While your at it a Robson Racing solid outdrive could be handy too. These parts can be found at most Vendor stores and other online Hobby shops. |
03-21-2011, 02:06 AM | #4 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
a well adjusted slipper is your friend. if you already have one (and it is adjusted correctly) then you have a gear mesh issue. |
03-21-2011, 06:53 AM | #5 | |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
There's also something to be said for keeping the weakest link easily accessible and cheap to replace. | |
03-21-2011, 06:09 PM | #6 |
Slippers are for weenies. Stock spurs are fine, I like the Kimbroughs too. Gotta have a fuse somewhere, might as well be a $3 part. |
03-21-2011, 06:24 PM | #7 |
Quarry Creeper Join Date: Nov 2010 Location: Toronto Canada
I fully agree with Duuuuuuuude, I would rather a readily available part let go than some other part that may take a week or more to order. Also loose the slipper, I changed out my slipper because it was just annoying I knew the truck could do what I was trying to get it to do and of course the slipper would kick in. I had it as tight as it would go too.
03-21-2011, 09:22 PM | #8 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
what are you guys using for slip eliminators and where to get from........bob .... |
03-21-2011, 09:43 PM | #9 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
The parts tree for it is ax80009 and it is part 6 and ax30197. Check your manual. Or look for the instructions for the transmission
03-21-2011, 10:19 PM | #10 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
In all the time ive had my AX10 ive never, EVER run a slipper. Ive only broken 1 outdrive and that was because the car got into a jam way far away from me when the driveshaft got jammed on the skid plate Ive only killed 2 or 3 spurs and that was due to bad mesh, and old age. In the end it boils down to skill and doing a good job of meshing the gears. I don't care what your running, you mesh it wrong, it will die. Ive killed hardened clutch-bells on my truggy by improperly meshing them, and i wasn't thrashing the car either |
03-22-2011, 12:54 PM | #11 | |
03-22-2011, 01:06 PM | #12 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Are there any 32p spurs that will work???
03-22-2011, 02:35 PM | #13 |
03-27-2011, 11:29 AM | #14 | |
03-27-2011, 11:44 AM | #15 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
I was running a 21.5T brushless system and destroyed a few spurs. This is what I'm running now: http://www.liquidrc.com/index.php?ma...ducts_id=55477 I'd also recommend picking up a better that stock motor plate. A little flex can hurt ya: http://billet-works.com/axial_ax-10_parts Finally make sure the mesh of the spur and pinion have a little play. When I first got into this hobby I destroyed one just because the mesh was too tight. |
