04-25-2011, 05:44 PM | #1 |
Rock Stacker Join Date: Sep 2009 Location: tacoma
| need help
not sure if this is even were i should put this cause of what it is i just put ax10 axles on a losi comp crawler chassie and the issue im having is that i have no low end power im running a 55 turn motor with a 14 tooth pinion the truck goes fast but can not crawl any suggestions |
04-25-2011, 06:06 PM | #2 |
You can't use those axles with the Losi transmission, there is not enough reduction. You either need to swap in an Axial transmission, or go back to Losi axles.
04-25-2011, 06:27 PM | #3 |
Rock Stacker Join Date: Apr 2011 Location: Tacoma
Sorry this is totally off topic but I live in Tacoma as well, where do you crawl?
04-25-2011, 06:43 PM | #4 |
04-25-2011, 06:46 PM | #5 |
04-25-2011, 08:42 PM | #6 |
| Still not enough. The Losi tranny is nearly 1:1, while the Axial tranny is considerably higher (can't think of the exact ratio at the moment). The Losi axles have buttloads of reduction in them, like 127:1 or something. You aren't going to get that with a 4:1 reduction unit. Besides, once you've spent time and money cobbling something together that MIGHT work, you could have just put the known right parts in and been done with it.
04-25-2011, 09:07 PM | #7 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I agree with Duuuuude...swap the axial trans in, or go back to Losi axles. Casey |
04-26-2011, 12:54 PM | #8 |
losi worms are toast and this is just a project for a friend i run an xr10 but thanks for the info ill try another route
