04-30-2011, 01:04 PM | #1 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| Hobbes 2.0
So after the success of my first build thread {} I took my car to Florida with me and pulled a few rod ends, blew a few driveshafts, had a blast and figured out a few things to change on the car when I got back home... so here we go with the upgrade. If your wondering why the car is called "Hobbes", Calvin got older and traded his tiger in for an AX10 Before Florida: In Florida Last known pic before the car got torn apart Planned changes are: Prototype Rocker chassis that is SLANTED like an MOA chassis to improve breakover new BLACK Delrin rims with adjustable offset {same ones Duuude is running on his Fastback} Narrower rims for the Sedonas Losi shocs with modified caps, spring cups and RC18T blue "front" springs Improved electronics, Sidewinder V2 with crawler programing... holy drag brake on a worn out Novak 55T motor Clocked front knuckles with axle tubes anything else that is evil that I want to put on it |
04-30-2011, 03:21 PM | #2 |
Sorry for cell pics, ill get some better ones later with my real camera Some dying later {first timer so feel free to bash it } Some assembly later and were running 3.2" front and 3.8" rear... something tells me that something is SLIGHTLY wrong with this picture... just slightly |
04-30-2011, 05:04 PM | #3 |
Newbie Join Date: Mar 2011 Location: OMAHA
Nice I like the orange color! The shocks look good let me know how they work with the new set up.
04-30-2011, 05:24 PM | #4 |
Thanks, its Rit "Tangerine" and I really like it!!! It is even more killer in person Notice a slight resemblance As for the caps, they work amazing! I drove the car some before I tore it apart and I was pleased with the spring rate {45WT inside} and they are staying up front, the rears are staying big for now... time to lower this high-rider Till I get the body-less upper made, the slant wont be so extreme, I am keeping it as is. I decided to throw it into a poser for the heck of it. I do like having the slanted skid, it is something simple but should help with breakovers... Feel free to keep the comments coming, CAD drawings of the parts I intend to add later |
04-30-2011, 05:59 PM | #5 |
Very nice. I made a chassis with a slanted skid a while back. Its a great idea that no one has really latched onto in the shafty world. Good to see someone giving it a go. |
04-30-2011, 06:40 PM | #6 | |
More work later, I got to deal with some binding on the front plate, and/or get my ground clearance in check, its still way to high. I am aiming for about 2.625-2.75 front and maybe near 3" rear, well see. I don't think a DIG would work well since it would put the driveshafts at even more of an extreme angle but if I have time I will mock it up with the Eritix dig I now have | |
04-30-2011, 07:13 PM | #7 |
04-30-2011, 07:33 PM | #8 |
04-30-2011, 11:48 PM | #9 |
So cool as the slant chassis is... for now its being taken off. Late Monday night or early Tuesday morning the car has to be on a UPS truck to Florida and I still need to finish my rims up and a few other things for it but fear not when I get home and life settles down I will give it another try. I may re-mill another one with less of a slant for a try. This chassis was originally designed for an MOA so it was extra steep on purpose! Tomorrow I get to break out the dying equipment again to dye up an original Rocker chassis in white Delrin. Then Monday I will have my bodyless upper made, the car hopefully finished rocking the new rims and were good to go. I will say in the little bit of testing, with almost no front articulation, that having a slanted chassis is very interesting indeed! I think it would work with some refinement... |
05-01-2011, 11:23 PM | #10 |
So some dying later... and I present to you the Orange Rocker {before you say anything I know it is slanted back... more on that later} While the chassis was soaking in the dye tank I turned into "Dr. Chassistein" and hacked up 2 poor "scrap" rockers {they had major machining flaws that made them unacceptable for sale.} I was mocking up how my uppers would mount for the bodyless upper I plan to mill Monday. So far this is what I came up with and I like the fact that I can easily prototype out a few different uppers super easy... hmmm After some assembly I figured out one... MAJOR problem! The front shocks {running blue springs and 45 wt oil} are way stiffer than the rear whites and 45 wt oil... so to fix this will require switching back to white springs up front... not what I "wanted" to do but it will all work out in the end. I think I need to track down some softer front springs, and I will bring the gear to Florida with me to change between Losi springs and any soft ones I can find there for testing... in the meantime its a mad dash to finish up what needs to be done and work on getting the car on a truck to Florida! As for the slant chassis if I have time I will mill one up and bring it with me. The major difference is the slant will NOT be as extreme. Between the two tranny mounts, 1.5" of travel, the whole mass moved up .5" which made for a REALLY steep slant. Great for the MOA prototype it is... BAD for a shafty I still think a pre-slanted chassis would be really nice so you don't have to mess with crazy shock angles, hmm food for thought |
05-01-2011, 11:33 PM | #11 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Angled skid, and I am sure I am not the first maybe not as severe but angled none the less. |
05-01-2011, 11:33 PM | #12 |
For reference, here's a shot of my slanted chassis. I thought I had a better pic, but I can't find it at the moment. There isn't much rise, but its still noticable when looking straight on from the side. I sent this one to Manning to test for a while, and he seemed to like it. I never really ran it in its aluminum form, but the plastic proto I built seemed to really benifit from the slanted skid. Last edited by Duuuuuuuude; 05-01-2011 at 11:35 PM. |
05-01-2011, 11:35 PM | #13 |
Highlucks: I meant the slant was "machined into" the skid like all the MOA chassis seem to have... Duuuuuude: WOOO SHINY! That aside that seems familiar... someone made a chassis for the AX10 that used springless front shocks, sprung rears and was pretty much a 60/40 setup, that was interesting, is that the same as the one pictured? I am starting to debate a tapered skid also, hmm maybe well have the Pretzel chassis next |
05-01-2011, 11:41 PM | #14 |
This? |
05-01-2011, 11:43 PM | #15 |
05-01-2011, 11:46 PM | #16 | |
TT wasn't too bad. Its all in the tuning. Here's the original Creeping Death chassis with drooped Revo shocks. Last edited by Duuuuuuuude; 05-01-2011 at 11:48 PM. | |
05-01-2011, 11:48 PM | #17 |
| Right right... well I did a quick googling and it "seems like" the only chassis that have any kind of pre-slant are MOA... well it won't be the first time I have broken the mold I know i can't go to wacky but I think at least .25" rise should be better than none!
05-01-2011, 11:52 PM | #18 |
| I edited my previous post with a shot of the Creeping Death, which has a kicked up skid and has been around for a while. There was one other that I have seen that has it, but I forget its name. I want to say Reign made it, but I'm not sure.
05-01-2011, 11:55 PM | #19 |
| Got it... it is still a cool design for those who like droop rigs... as for me I love spring rigs. If time lets me I want to see if the "circle shock mounts" on the Rocker is really the best vs. the usual designs... this should be fun |
05-02-2011, 12:30 AM | #20 |
Semantic I know, but the slingshot has an angled skid from the machining. Angled front and rear, but still angled. As posted on the BWD web site it was the first chassis (or production chassis) to have a curved skid.
