04-30-2011, 06:05 PM | #1 |
Newbie Join Date: Dec 2010 Location: Panama city
| UPgrading steering servo
THinking of upgrading my stock servo to the hitech 7950. Obviously that alot more torgue on everything like knuckle. What all else would I need to upgrade. I was thinking vp knuckles but not sure which ones.
04-30-2011, 06:13 PM | #2 |
Knuckles, carriers, and tie rod need to be upgraded to metal if they haven't been already. You'll also want a bec if you don't have one (they're mandatory once you go above stock), preferably the one from Castle Creations. Its also a good idea to have a radio with end point adjustments. If you spend a good deal of time with the steering at full lock and the servo still trying to push, it'll burn out eventually. |
05-01-2011, 08:12 AM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: Mid TN
Im in the process of upgrading to the hitec 7950th also, I also got the castle creations bec already programed at 6.0v I have not started install. Im still searching the best way to wire this up. I have ckrc crawlers knuckles and axle carriers and the axial aluminum steering upgrade kit.
05-01-2011, 10:34 AM | #4 | |
05-01-2011, 12:36 PM | #5 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
| What I did with mine. If you are using a programable ESC, but sure to NOT cut the power wire to the ESC plug, just pull it out of the connector. That way if you need to reprogram, you just pop the pin back into the connector.
