06-21-2011, 06:04 PM | #1 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
| AX30794 WB8 Driveshaft Set The WB8 Wild Boar Driveshafts are the factory units used on the Wraith™ are THE perfect upgrade for all SCX10/AX10's. We named this driveline system after your driving style – WILD BOAR. Yes, we watch YouTube and see your super thrash 'n' bash style SCX10 & AX10 abuse! We've watched you drop kick your clutch, throwing caution to the wind and your rig into the gnar-gnar where only the wild boar can go without an ounce of fear! We love that you trust the Axial brand, but there is neither gold, glory nor any photographer hundreds of miles into the forest. We want to give you that extra security to be able to drive home and tell us about it. The Axial R&D team took all of this into account when working on a new driveline system solution that would not only be great for the Wraith™, with the next level of driving style we are sure your vehicle is to see, but deliver a factory system that is an easy-to-install mechanical upgrade for all SCX10/AX10's to make sure you come back home from the epic journey. The WB8 Wild Boar Driveshaft Set is THE ONE simple system that will universally work across the whole Axial family of rigs. Yes, we said "simple system", as in – Super Easy Assembly! No more pry bar pliers! No more snapping Y-Yokes! The WB8 Wild Boar Driveshaft Set is a much simpler solution to assemble, tear-down and inspect. Other features include: - Constant Velocity Joint Design [CVJ] - Full Metal-To-Metal Construction for the CVJ-Housing - Friction Free Movement / Smooth Articulation - Metal Ring Protection & Capture for the CVJ-Pin - Easy Assembly & Maintenance - Three tube lengths for various applications [Wraith™ / AX10 / SCX10 Dingo™ & Trail Honcho™] OPTIONAL: We recommend using [AX30435] along with [AX30408] to utilize the cross pin design for secure pin attachment. The Axial R&D team worked on a solution that would not only be great for the Wraith™ but would also make a great upgrade for all SCX10/AX10's. Visit the link below for more information http://www.axialracing.com/ftp/ax307...shaft_set.html Part Info AX30794 WB8 Driveshaft Set (2pcs) AX30166 Pin 1.5x11mm (6pcs) AX30408 Input Shaft 5x29mm (2pcs) AX30435 Steel Outdrive Shaft Set (2pcs) AX30463 WB8 Universal Joint Rebuild Kit (2pcs) AX30784 WB8 Driveshaft Coupler Set AX30786 WB8 Driveshaft Retainer Ring (Aluminum) (2pcs) AX80084 WB8 Driveshaft AXA0175 Screw Shaft M3x2.5x11mm (10pcs) |
06-21-2011, 06:58 PM | #2 |
It's about time. What is the projected investment to complete 1 truck?
06-21-2011, 07:00 PM | #3 |
Hoorah! Driveshafts with crosspins! |
06-21-2011, 07:00 PM | #4 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Just saw these today on a Wraith at Hobby Town and they looked great. What is the longest they can be run at safely?
06-21-2011, 07:02 PM | #5 |
06-21-2011, 07:05 PM | #6 |
06-21-2011, 07:43 PM | #7 |
06-21-2011, 08:46 PM | #8 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
06-21-2011, 09:29 PM | #9 |
06-21-2011, 09:47 PM | #10 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Hoorah! 4mm set scr......oh shit. Neverminid. Casey |
06-21-2011, 09:59 PM | #11 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
06-21-2011, 10:41 PM | #12 |
06-21-2011, 11:28 PM | #13 |
06-21-2011, 11:42 PM | #14 |
| I forgot to mention that 2 of the yokes had stripped out 3MM screws in there, THAT made it a pain A lot of grease, and forcing on the drill press and we got it done |
06-21-2011, 11:57 PM | #15 |
06-22-2011, 12:09 AM | #16 |
06-22-2011, 02:26 AM | #17 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
Nice, now just come out with hardened OD/UD/Standard gear sets with holes for the crosspins! It's a pain to drill out the hardened sets. When are the driveshafts going to be available to the general public?
06-22-2011, 08:03 AM | #18 |
06-22-2011, 11:58 AM | #19 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
these are great but for the price and if you look on axials web site at the shafts they are stuck to a parts tree. Too me this means they aren't all metal just the yokes
06-22-2011, 02:00 PM | #20 |
The joints are what take most the abuse since they run at an angle. I personally like the idea of having a little "give" or twist in the shaft to absorb torque spikes. Plus it keeps the weight down. However, I do think it is an epic fail for not having 4mm setscrews/pins. I do think the price is a little steep considering I can get a pro-pack of Traxxas shafts for less than ten bucks and they have a decent lifespan. |
