10-09-2011, 04:30 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Seattle
| Electronic help.
Hi guys recently I bought a used Axial AX10 Scorpion, came with a metal gear servo brand unknown no sticker. Duratrax 8t racing speed controller 55t axial motor. Well sometimes its fine and other times its not. Every now and then it when turning right the servo tweaks and make a funny sound causing everything not to function. Throttle and reverse don't respond. This rig has seen better days. Can the servos cause this? I think the speed controller is fine not the best but fine for now. I've purchased a 2.4ghz Losi Spektrum ready radio for it witch I thought the old FM radio that came with it could be the problem. But it's not both radios are working fine. Here's a little video, sorry i'm feeling a little under the weather note my excitement. Future upgrades will be a Tekin FXR w/55t motor jk body and a few other goodies, and possibly a new servo asap. http://youtu.be/v0gpCS7Fl-Y Last edited by RCBreeze; 10-09-2011 at 05:05 PM. |
10-09-2011, 05:07 PM | #2 |
Newbie Join Date: Nov 2009 Location: Coffs Harbour
I have had similar probs and yes it was my servo. i opened my servo up and found that the little brushed motor in it thay were shorting out so i just got a new one and it is fine.
10-09-2011, 07:10 PM | #3 | ||
| Went downstairs and checked my 'box-o-spare-stuff' because I thought it might have been a Hitec servo, but all my Futabas have that bump on top where your tag has fallen off. Quote:
Not a bad idea. Maybe a Castle Creations 10 amp BEC, too? | ||
10-10-2011, 05:24 AM | #4 |
Quarry Creeper Join Date: Apr 2011 Location: United States
9 times out of 10 this means that you need an external bec on your truck to provide enough amps to run your esc and servo while turning. Basically your esc is probaly trying to reset while turning because of the amp pull of the servo. This has happened to me on every truck i have ever messed with
10-13-2011, 04:24 PM | #5 | |
