10-20-2011, 05:36 PM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: dayton.tn
| TEAM423's ax10 comp buggy
my ax10 comp rig has a comp 55t aftermarket plate chassis a couple 945 servos for the front and rear steer,it has blue dot rovers and runs on lipo.I also got a venom creeper comp rig that is also built..my question is they both got bug bodys and i cant get my axial lower to the ground..shocks iam thinking...what u think?
10-20-2011, 06:33 PM | #2 |
here are a few pics of my comp-buggy |
10-20-2011, 06:46 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: Marsing ID
you could get shorter shocks or do a drop suspention. this requires you to pull the shocks apart & place a spacer on the shaft (some use fule tubing) then slide it back in the body & put it all back together. |
10-21-2011, 03:49 PM | #4 |
sounds good..let me try that..thanks
10-21-2011, 04:18 PM | #5 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
The fuel tubing will serve as a limiter for the shocks, if you place it on the shock shaft inside the shock body it will reduce the extension of the shock by the length of the tubing. So squish your suspension down to the point where you want it and then release it. Do that a few times and look at how much each shock compresses and cut 4 pieces of fuel tubing to match. Put them inside the shock body, on the shock shaft. | |
10-21-2011, 04:39 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
I have that same chassis it was designed for moa rigs so its both shorter in height and in length than a stock chassis. I set mine up with a 3" shock limited by 6mm. The shocks are still angled enough that you get good articulation but not too much....just my 2cents nice to see someone else took the chance to build a shafty with that chassis.
10-21-2011, 07:56 PM | #7 |
thanks 707 this thing does real good it has killer flex in the back..its only problem is body roll.. sits up a little to high..when i fix that we will be golden
10-21-2011, 10:50 PM | #8 |
You know that rear steer is not allowed in comps, right? |
10-22-2011, 05:42 PM | #9 |
yes i do..me and my buddys put our own comps on and some have dig and some have steer so our comps are RUN WHAT U BRUNG...so everybody can ride |
10-22-2011, 05:55 PM | #10 |
this might sound funny..but where is the for sale page at?
10-22-2011, 07:10 PM | #11 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
10-22-2011, 08:36 PM | #12 |
thanks doc...
