12-07-2011, 03:42 PM | #1 |
Newbie Join Date: Nov 2011 Location: redding
| A few newb questions
IM WANTING TO GET A AX10 SCORPION, MY LAST RC I BOUGHT WAS A 4X4 FROM RADIO SHACK FOR $80 IN 2003, SINCE THEN IV WHEELED MY 1:1 TOYOTA. i HAD A FEW QUESTIONS IM CONFUSED ABOUT.. IVE HAD A 1:1 CRAWLER FOR ABOUT 7 YEARS NOW MAYBE IM TRYING TO COMPARE IT TO MUCH TO A AX10 1. DOES THIS COME WITH NO LOCKER IN FRONT, I HAD READ THAT IT COMES IN THE BOX AND YOU INSTALL IT YOURSELF AND IF SO HOW MUCH WEAR AND DAMAGE WILL IT DO DRIVING ON THE PAVEMENT, NATURALLY IM GONNA BE PLAYING WITH IT IN THE ROCKS AND DIRT BUT SHOULD I BE AFRAID TO PLAY WITH IT ON HIGH TRACTION SURFACES FOR LONG PERIODS OF TIME? 2. HOW FAST IS TOP SPEED ON THIS THING STOCK, AND IM SURE I WILL GEAR IT DOWN (70:1 I BELIEVE WHAT THE SPECS SAY) IS IT JUST A SWITCH ON THE TRUCK OR CONTROLER I MOVE TO DROP IT DOWN INTO CRAWL GEAR, OR DOES THE WHOLE PINION GEAR GET SWAPPED OUT AND I LOSE MY STOCK TOP SPEED? 3. ARE THESE SOME WHAT WATER PROOF IVE WATCHED U-TUBE VIDEOS OF STRAIGHT UP MUDDING AND WATER BASHING, ARE THESE PRETTY WELL PROTECTED I DONT SEE MYSELF GOING THRU ANYTHING EXCEPT TALL WEEDS AND GRASS THAT ARE WET |
12-07-2011, 04:13 PM | #2 |
Rock Stacker Join Date: Jan 2007 Location: On the rocks
Search is your friend It comes with lockers installed,The wear and tear you get on a 1:1 doesnt happen on a rc crawler as easily,it does not come waterproofed you will need to do that yourself there are threads on here that will answer every question you have you just have to look!! Oh and this is a disease!!~ |
