01-10-2012, 07:29 AM | #21 | |
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
| Re: My ax10 rtc build Quote:
1. spend the money upfront and be cheaper in the long run, get a hitech 7950th or 7980th. Also I chose a SAVOX 1268sg for the 347oz/in torque for 75$ at LHS. next is a good horn. 11$ from savox and its aluminum and made for it. 2. answered in 1. 3. My hammers worked fairly ok after siping the large solid blocks. However i just installed new sedonas and didn't do one thing to them and they have pulled me thru tons of places the hammers modified wouldn't. 4. Now battery plate. A lot of options here. I say stay with the AXIAL plate but don't buy it seperate. Purchase it in the BTA(behind the axle) steering kit(Axial Racing: AX30533 Behind the Axle Steering (BTA)). Mount it up and drill your holes for the 4 link. The kit is roughly 48$-55$ and includes all your hardware, links, high angle knuckles and rod ends. this gets your steering links up and behind the axle never to be hit again or hung up on. BTW if purchased seperately the cost is over 80$ next get the C hubs and your done with the front. 5. I would purchase the 4" losi comp shocks with soft springs. Seems to be alot of people running them in comps even on the XR10 and bergs. thats what i plan on doing. 6. I can't give any information on axles. haven't ventured that far yet. 7. I just purchased a Castle Creations BEC (battery elimination circuit) check out Castle Creations website. it explains alot. | |
01-10-2012, 03:04 PM | #22 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
I am also a new AX10 owner. Here are some links to get good info and ideas, a lot of which are free mods you can do: 1) K.O.M.'s Newbie Comp Build 2) RCCrawler.com- Your #1 source for Radio Controlled Rockcrawling! 3) Budget RTC Build Have fun |
01-10-2012, 04:20 PM | #23 |
Newbie Join Date: Jan 2012 Location: quebec
ok with all reading ive done there is my new list done: trim foam and body mount battery on the servo tranny mirrored elctronic on top put my 4 lower link inner my skidplate ordered list: aluminium link kit+hardware supersoft axial comp shocks red to order: axial aluminium c hubs and high steering knucke hb rovers withe dot savox sc-0251 with an alu horn upcoming ideas but not sure tube frame(fastback 2 or proline) bta steering dig heres some pic of my rig as is today: |
01-10-2012, 04:42 PM | #24 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i have the same rig and im running the hammers too but i got some birthday money so thinking im getting buck up and get a decent of tires.. not sure what kind yet though.. im thinking maybe sedona's or maybe even a TSL with stiffer foam.
01-10-2012, 04:52 PM | #25 |
Your driveshaft angle looks to be a little too much.
01-12-2012, 05:47 PM | #26 |
just did my front axle plate with my top battery/esc plate now all is on front and just need holes for 4 links front and rear pics to come Last edited by qcax10; 01-12-2012 at 06:45 PM. |
01-13-2012, 09:49 PM | #27 |
and all the mods ive done yet costed me a big total of 5$ cdn sure if i count my ordered parts(still not received) im at 90$ cdn |
01-18-2012, 09:43 AM | #28 |
I would definately look into a castle creation BEC 10A and run a lipo 3s 11.1v on the front instead of the big NIMH battery. do it all at once with the Axial bta kit. gives you your knuckles, steering links and plate for the battery all in one nice little package.
01-18-2012, 09:50 AM | #29 | |
Mirror Imaged Transmission By mirroring the tranny while looking down on the car from the rear, the stock motor location is on the left rear and when its mirrored its on the right front and the gears are facing toward the rear. Did you have to redo the polarity on the motor to do that and is your radio triggers reversed now? Last edited by donhd04; 01-18-2012 at 09:56 AM. | |
01-18-2012, 11:56 AM | #30 |
^^ yes i think he does IF he's planning on running a dig. but if he decides not to this is fine, i've flipped my skid and now with the new tires i have very little TT.. so here's an updated list of what i bought with my birthday money: -went with the Hot Bodies Sedona's, i've seen them work and have used them briefly on a friends crawler mine are getting a sipe job because they side slip too much. -i went with a hitec 7955TG steering servo, i've also seen these work and have played with them briefly on a friends crawler.. you have a good list of mods going.. get an aluminum steering links on the front ASAP. dont worry about the tires or any of that until you get the links because plastic sucks and they bend like a pretzel if one tire binds and the other moves and possibly break parts and make the switch to lipo, way smaller and lighter.. you'll need a lipo charger too. my friends and i have this charger..2-3 Cell LiPo Balancing Charger, 0.65A (EFLC3110): E-flite - Advancing Electric Flight.. you'll need a power supply too (the cord that plugs into the wall)... i got lucky and a friend i bought a friends old lipo's for 1 dollar each haha i bought 5 and he had an extra power supply so it only cost me like 20 bucks.. or you can go the thunder ac6 route. im running a 2s 800-850mah with a high torque servo (300+oz) and im not running a BEC and with no problems... |
01-18-2012, 12:59 PM | #31 | |
This was recommended to me from Chris the battery man on rccrawler. fits snuggly on the servo battery tray on front axle with no binding. CheapBatteryPacks - Elite 1300 11.1V 35C Lipo Pack this is also the charger he recommended for it as well. Plugs of any choice were free and installed and adapters were free also. CheapBatteryPacks - CBP 6i50 Balancer/Charger AC/DC Both of those have worked flawlessly so far and they both get used at least 4-5 times a weekend. If i would buy a second battery i wouldn't have to wait on charge times which with a 35C is about 60 min. I'm getting roughly 1.25 to 1.5 hours of run time and im not easy on the trigger either. My local hobby shop has GEN ACE 1350 35C 3S 11.1V LIPOS for 15$ each so those will be my next battery. same size as the elite battery packs from cheapbatterypacks.com | |
01-18-2012, 04:11 PM | #32 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
A few tips from my experiance in the last year. 1. The Axial aluminum upgrade looks nice, but the link ends are weak. Use some Traxxas link ends, the plastic is thicker and the ball is metal. 2. You said you ordered red springs? 3 of the ones you have now should be reds. Like others have said, go Losi golds. 3. Yes BEC is a must, especially with a servo upgrade. And don't skimp on the servo (unless you enjoy replacing it). Get a good high torque one. Also if you don't have a Castle Link, get one when you buy the BEC. It will let you set the voltage on the BEC, and let you change your ESC programming. 4. As for weights, put them on the axle tubes as low as possible without going under the tube. Also put them in the front wheels. I'm still working on getting mine setup well, I've done a lot of things that I had to redo later (don't get CVDs), but have almost dialed it in after 16 months. If you plan to find a local group and comp it, you'll quickly find the flaws. |
01-18-2012, 07:34 PM | #33 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
No one runs a dig on these things anymore, don't worry about it! As far as the stock servo plate, that thing has some ****ing phenomenal geometry dialed right into it. The servo mounting holes are perfectly set up for upper links. Use some spacers to raise the links up from the top of the plate by 1/4" and you can use links about the same length as your lowers. This will rotate the pinion up (when viewed from the side) and the link mounts back towards the center of the axle (when viewed from above). I think I have a nice picture of me doing just that. In my thread I kind of detail the things I did and for the most part why to get from stock RTC to where I am now (not much farther ). |
01-22-2012, 04:47 PM | #34 |
big update this weekend drilled my 4 wheels and added 2.5 oz in each rear wheels aluminum links upgrade and custom 4 link on the rear |
My ax10 rtc build - Similar Threads | ||||
AX10 RTC to Edge build, 1st timer | WAM | Axial AX-10 Scorpion | 3 | 05-28-2011 12:25 AM |
my ax10 rtc | desertrunner | Newbie General | 4 | 01-21-2010 09:30 PM |
ax10 rtc | river rat | Axial AX-10 Scorpion | 5 | 08-09-2009 06:25 PM |
ax10 rtc | 24inchapes | Axial AX-10 Scorpion | 4 | 07-12-2009 07:17 PM |
