02-16-2012, 06:03 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| tires and bodies
i might be building an ax10 scaler/comp rig. i want it to look real but perform like a comp crawler. i will probably use an axial swx chassis for my ax10, i dont know what tires or body i should use to make this look awesome. post up your pics of ax10's so i can see how some tires and bodies look
02-16-2012, 06:16 PM | #2 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: tires and bodies
you better hurry up and get that swx chassis because i think they are discontinued is what im hearing. mine is just the stock ax10 RTC body and running hot bodies sedona tires. here's a friend's ax10 ARTR with a honda civic body also running the HB sedona's here's a friends ax10 with a datsun 510 body and is running HB sedona's too and the swx chassis. im pretty sure the older ax10's came with a betty(?) body or something like that... what kind of chassis are you looking at using??? |
02-16-2012, 06:17 PM | #3 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
i love the hot bodies white dot for comp crawling. as seen in the first 2 pics the tsl's impressed me too on crawling but i would choose hb white dots for comp crawling though.. |
02-16-2012, 06:19 PM | #4 |
im probably gonna use an swx, you can find them on ebay for like $80. im designing my crawler in my head. so far it's gonna cost ALOT. but it's going to be badass!!!!!!
02-16-2012, 06:21 PM | #5 |
these are all awesome rigs, but i want something that is scale looking but performs great.thanks
02-16-2012, 06:39 PM | #6 |
you asked for ax10's not scale looking rigs.. my honcho is a scx10 and it crawls awesome.. i'll keep my 80 bucks and make my own swx chassis. the datsun runs the swx chassis the other 2 run the ax10 chassis.. i still dont understand exactly what your asking.... so you want to run the swx (which is a comp chassis and is like 2" wide) but you want run a scale body?? do a quick search and see what you can find. give us a little more info on the specs you want and we'll see if we can help you out a little more |
02-16-2012, 06:54 PM | #7 |
i did a little searching, and found what i was looking for. it was this crawler RC4WD Mud Slingers 2.2" Tires Soft (1x Pair) [Slingers2.2]*-*2.2 tires*-*Tires*-*-Wheel Products*-*The Crawlers Store LLC |
tires and bodies - Similar Threads | ||||
Are there bodies that fit over the tires? | skadebo | Axial SCX-10 | 16 | 03-18-2010 06:06 PM |
Hot Bodies Tires | Rock Concepts | Tires and Wheels | 264 | 01-15-2009 11:35 AM |
