05-19-2012, 03:38 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| CreationFab's quickly thrown together Sporty
We have a comp this weekend we decided to start the 2.2S class in, and I wanted to slap together something real quick for PCC also. So I decided to throw together a really basic ax10 based shafty. I am also hoping that the misses shows an interest in driving this in the sportsman class, but I wont get my hopes up there lol. I have about 8 hours into it so far. This will be good enough for the weekends comp. But I will be tweaking stuff until I like it. It seems to drive well enough. Might need an oz or 2 on the front, but it should work well for Tomorrows comp. Drives really smooth also. I did notice that the caster on the passenger side is off when I uploaded the pics More to come... Specs: Front axle: -AX10 housing -CreationFab delrin wide splined tube -XR universals -HR spool -Axial over drive gears -VP Chubs and Wraith knuckles -VP shock raisers Rear Axle: -AX10 housing -CreationFab delrin wide un-splined tubes -XR10 rear inner shafts(long side trimmed down) -XR plastic lockouts -HR spool -Axial under drive gears Trans: -AX10 trans -VP alum housing -Roninson metal gears inside -HighlandCrawler outdrives -87t spur -Losi comp crawler drivelines Chassis/suspension: -Gatekeeper GC3 chassis with skid modded for traxxas ends -Lunsford TI lowers bent up -3.5" big bore front shocks with rod end mod, 15wt oil, pink Mini-T springs, and jeepin doug spring cups -4" big bore front shocks with rod end mod, 15wt oil, orange Mini-T springs, and jeepin doug spring cups Wheels/Tires: -VP SLW's 1" wide -VP .450 hubs -HighlandCrawler full faced delrin rings -HighlandCrawler Red Khaos/Rover narrowed tires -Crawler Innovations double deuce closed cell foams Electronics: -GTB3 Radio/RX -HiTec 7954SH servo with Robotronics arm -Castle Mamba Micro Pro -CC BEC -Holmes 35t sport motor with Losi 13t pinion -Elite 850mah 25C 4S batteries |
05-19-2012, 03:46 PM | #2 |
Relaxed ! Join Date: Apr 2009 Location: On the road again !
| Re: CreationFab's quickly thrown together Sporty
Oh my ! The gorilla comp at the pcc is gonna be more fun then throwing poop at the monkey's
05-19-2012, 05:54 PM | #3 |
Looks like it'll give The Masami Special a run for it's money. I better start practicing so I can show you how ut's done!
05-19-2012, 08:46 PM | #4 |
That looks like a killer rig, but simple and quick?
05-19-2012, 10:11 PM | #5 |
Pebble Pounder Join Date: Feb 2010 Location: Rapid City
| Re: CreationFab's quickly thrown together Sporty In response to pic #3. Nice quicky build Chris. Please get that bec for the Cheat. |
05-20-2012, 12:54 AM | #6 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
Looks like ( )*( ) butthole |
05-20-2012, 06:38 PM | #7 |
Looks like a good rig man. Nice little put together |
05-20-2012, 07:20 PM | #8 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
Thrown together! HA. I hope mine looks that good after I get done with a three month build.
05-21-2012, 11:10 AM | #9 |
Thanks guys. She drove really well at our comp yesterday. I let the misses drive her in the sportsman class, and I drover her in our 2.2S class. The misses drove really well with me coaching her, and managed to finish all 4 courses in the pouring down rain! Only her second time driving a crawler ever. I on the other hand didn't do as well lol. Messed up a tube on one side because I was lazy and didnt put as many screws in it as I should have, broke a driveline, and the RX got wet, so the truck was wigging out. But all in all, the thing drove like a baws! I am thinking of making some carbon side plates with the same link geo, but a cooler, lower design, new upper links, carbon axle plates, and some other tweaks. More to come...
05-28-2012, 04:38 PM | #10 |
Made a couple changes. The drivers side tube got all screwed up at the last comp, so I made a new one, and ended up Gluing it in to one side to secure it nicely. I even found an even better way to set the caster even. For the caster, I just set both chubs on 2 flat surfaces and made sure they were even on it. Then I let the glue dry and threw in some screws to keep it from ever coming un done. Then I took the rest of the GC3 stuff off that I was "borrowing" from a truck I parted out. Made some carbon axle plates and extended the upper links. The front now mounts through to the servo mount. This will keep it stronger and less likely to break the carbon Made some new upper links. The rears are just temp recycled ones. Going to make some lighter ones later on. Just have limited time right now More to come... |
05-28-2012, 05:54 PM | #11 |
Are those spring retainers custom?
05-28-2012, 08:58 PM | #12 |
| Re: CreationFab's quickly thrown together Sporty |
06-26-2012, 09:55 AM | #13 |
CreationFab's quickly thrown together Sporty - Similar Threads | ||||
Got a RS10 thrown in on a trade | NICKH | Redcat Crawlers | 4 | 11-27-2011 05:23 PM |
Respond quickly | crawladan | Chit Chat | 11 | 02-17-2009 10:45 PM |
R2 quickly questions! | andres-tavares | Newbie General | 7 | 02-05-2007 01:03 PM |
