Thread: Ax-10 bind issue...
Old 06-27-2012, 10:30 PM   #1
Default Ax-10 bind issue...
My ax-10 is having a bind issue. Sometimes it binds up in some places it shouldn't. Haven't done much to mess anything up. Only upgrades are aluminum links, punisher shafts, and 2.2 swampers. Its not the driveshaft angle because the angle is almost strait. I think it's the slipper. I've never messed the tranny and I was gonna ask before I effed something up. I really don't know what the slipper is for so can somebody explain what it's for and why its binding? I would try to figure this out but I'm afraid to mess up the tranny up. Thanks guys.
Team_Jason_RC is offline   Reply With Quote
Old 06-28-2012, 12:57 AM   #2
Default Re: Ax-10 bind issue...
Need a little more info so we could help you out,like what gearing,motor
MR.VERTICAL is offline   Reply With Quote
Old 06-28-2012, 07:54 AM   #3
its not the slipper...
the slipper clutch is too take some of the stress out of the driveline..
when you bind it up instead of breaking parts it slips before something bad happens.
it sounds to me like you've got a screw too tight binding the axle or in the wrong spot.
ROLANDROCKSHOP is offline   Reply With Quote
Old 06-28-2012, 08:00 AM   #4
try to isolate the binding..
take off the driveshafts and spin the front/rear axles..is it there?
spin the tranny..is it there?
if its the axles try backing off the chub screws just a tad and see if it frees it up..if it does free up its your screws..too long,they were rubbing the inner axle shaft..same for the rear on the lockouts.
Old 06-28-2012, 05:16 PM   #5
It has stock gearing. A axial 55 turn motor running on a 2 cell. Ive never took the axles apart so I don't really think that's it. I'm thinking the motor doesn't have enough power to get out of some the binds....
Old 06-28-2012, 05:31 PM   #6
pics??
is it new or used?
can you hold the tires and the motor still spins??
tighten your slipper up..
Old 06-28-2012, 06:52 PM   #7
It's about a year old. And yeah I can do that....
Ax-10 bind issue... - Similar Threads
HR Dig bind issue need help pontiacfreak Newbie General 0 01-23-2010 01:57 PM
Bind help! ancichf Losi Mini-Rock Crawler 4 12-01-2009 02:02 PM
Bind!!?!!?! gooba Axial AX-10 Scorpion 15 02-17-2009 07:40 AM
in a bind wirywrangler HPI Wheely King 3 04-07-2008 12:22 PM
