Thread: Axial (semi tuber) in the works!
Old 06-30-2012, 03:22 AM   #1
Default Axial (semi tuber) in the works!
It's been a while since I built one, I'm using 1/4 rod and a mig welder. Still no tube or oxy/acetylene set up yet.
If anyone has suggestions please help
Criticism is welcome
BudLight is offline   Reply With Quote
Old 06-30-2012, 05:40 AM   #2
Default Re: Axial (semi tuber) in the works!
well hard to say, only 1 pic.
looks good so far.
perhaps try to tack/dot weld, that weld you have there will effortless hold up for 100 times your rc car weight.
they look good anyways.
nitrooxide is offline   Reply With Quote
Old 06-30-2012, 11:23 AM   #3
Proverbial threadkiller
Trubble's Avatar
I made a skidplate in Sketchup to turn my trans up on it's side like that, but have no means to get it made. Now that I'm wanting to go bodiless, hardly seems worth investing anything in a skidplate for my stock AX.
Keep us posted, I'm kinda interested to see how this turns out.
Trubble is offline   Reply With Quote
Old 06-30-2012, 12:59 PM   #4
looks good so far.
Thanks. The weld there was tacked i just tacked it all the way since it was for the tranny, figuring a lot of torque would come out of it plus that plate is really thin. I hope to get more up today.
Old 06-30-2012, 11:57 PM   #5
Little bit of progress
Still need to clean up the welds, suuuper tight fit with the motor.
Old 07-01-2012, 06:24 AM   #6
Location: Taylors Falls just hanging with the MNRCRC crew.
It's a interesting build so far you've obviously got something unique in mind.
Stormin2u is offline   Reply With Quote
Old 07-01-2012, 10:09 AM   #7
Something different....looking good....starting to do some myself, so watching this....
Postclanker is offline   Reply With Quote
Old 07-01-2012, 08:06 PM   #8
Thanks! Usually I just start bending cut and weld. Never really a solid plan
I think I'm going to start a different one. Do you have a link to yours?
Old 07-01-2012, 08:09 PM   #9
What I did last night. Not really diggin it though :/
Old 07-01-2012, 08:57 PM   #10
I think I'm going to start a different one. Do you have a link to yours?[/QUOTE]
Not yet...still gathering materials and tools. I will braze though, and anything related to that will catch my eye lately. I will share my progress as soon as I get halfway good at it.
Old 07-02-2012, 09:51 AM   #11
just a thought.
is not the motor more weight then the tranny?
woud perhaps be better to have the motor as low as possible??
Old 07-02-2012, 01:59 PM   #12
just a thought.
Yeah I knew that comment was coming but at the time I already had put it on and figured F it
Old 07-04-2012, 09:53 AM   #13
This is awesome so far. Question: is that tubing or solid rod? If rod, won't this be pretty heavy? Just wondered. Maybe the weight is part of your plan.
Josh_Br is offline   Reply With Quote
Old 07-04-2012, 04:14 PM   #14
Yeah it's 1/4 rod. The chassis is a ton I don't have money for tubing and I have about 100 ft of the rod.
No plan towards the weight, just that its all I have to use.
Old 07-04-2012, 06:11 PM   #15
I can certainly understand that. Good luck to you; looking forward to seeing how it turns out. I like the sideways tranny idea. Is that to make the truck more narrow in the center?
Old 07-20-2012, 05:44 PM   #16
yeah I thought it would look better. I scrapped this built and working on a "sporty" rig seems like thats the new thing
Old 07-21-2012, 10:02 AM   #17
Suck it up!
Duuuuuuuude's Avatar
Build it! Who cares what the "new thing" is. Do what you want.
Duuuuuuuude is offline   Reply With Quote
Old 07-25-2012, 11:48 PM   #18
I actually like the look of the new thing I'm working on. I barley have time to work on it now though..
Axial (semi tuber) in the works! - Similar Threads
semi scale 2.2 tuber dcrou7 2.2 Scale Rigs 3 04-25-2012 08:23 PM
semi-scale tuber build ToyTundra Losi Mini-Rock Crawler 4 09-02-2009 04:13 PM
tuber in the works VanDusen1 General Crawlers 5 06-14-2006 10:51 AM
tuber in the works fire627man General Crawlers 10 04-24-2006 12:57 PM
New tuber in the works. aubie Tamiya Clod Buster 19 10-14-2004 08:00 PM
