Thread: Weird Gears
Old 06-08-2015, 03:42 PM   #1
Default Weird Gears
Has anyone tried these? Event the pinion and spur teeth are cut at an angle.
josh6575 is offline   Reply With Quote
Old 06-08-2015, 07:13 PM   #2
Default Re: Weird Gears
Nope, haven't seen those yet.
Helical gears are supposed to be stronger...who makes 'em?
Solitaire is offline   Reply With Quote
Old 06-08-2015, 07:24 PM   #3
MODERATOR™
EeePee's Avatar
Has anyone tried this Ebay transmission?
EeePee is offline   Reply With Quote
Old 06-08-2015, 10:29 PM   #4
I think there supposed to be quieter also.
crawlerwon is offline   Reply With Quote
Old 06-09-2015, 05:47 AM   #5
They are commonly called pineapple gears are are supposed to be stronger and quieter
JAYDEN1999 is offline   Reply With Quote
Old 06-09-2015, 06:15 PM   #6
So from the thread EP showed. One guy bought them and liked them. Others don't like them, but never used them. I bought a set and will try as soon as I break something.
Old 06-11-2015, 03:37 PM   #7
The advantage of helical gears:
- slightly more contact area so in theory stronger
- They engage more gradually so run quieter / smoother
- load is theoretically more distributed over gear teeth
The disadvantage:
- sliding friction in meshing teeth thus slightly less efficient in power transfer
- thrust along the axis of the gear -> more pressure on the bearings
Most important though is the material. Helical gears made of weak material will suck just as normal gears of weak material will suck.
So basically I'm interested in what these gears are made of.
I'd love to give helical gears a try if they're made of hardened steel. If they're made of China butter, I'd rather not ;)
Pygmy is offline   Reply With Quote
Old 06-11-2015, 07:00 PM   #8
Pygmy you got me curious. I scraped one of the gears with a stainless scale. I am leaning toward the China butter. Curled off a chip with the rule. Harder than aluminum, but no where like the old bully gears.
Weird Gears - Similar Threads
RC4WD Gears or Axial Light Weight gears. OFFROADRCKOREA Axial XR10 39 10-29-2012 02:20 PM
***Giveaway*** - Mann Gears - HD Replacement Berg Gears mann0mann EnRoute Berg 72 06-20-2010 07:24 PM
