06-11-2016, 12:19 AM | #1 |
Rock Stacker Join Date: Jun 2016 Location: Beaverton
| New to ax10
Ive been interested in crawling for a while and finally took the chance on picking up a used ax10. It's pretty beat up and needs gone through from end to end. I don't plan on comp crawling with it, but willing to go the distance to make it a worthy weekend crawler. When I picked it up, it was all original other than the warthog chassis. Nimh battery and all. Ive tinkered around with it just enough to realize the warthog chassis is not the direction I want to go with it. Can't quite put my finger on it being I'm not familiar with all the terms yet but it just doesn't have the right geometry. Slowly but surely I'll get it where I want it. For now as it sits Ive thrown on a 3s, 1350mah 75c lipo mounted over axle, ae5 esc, CC bec, body panels and a 3ch tactic controller for now along with wheel weights and a couple maintenance items but I plan on taking it in another direction. For now, I have ordered a underground crawler fastback chassis and that should start me in the right direction. A lot of good info on here. I'll pick what I can from everyone's builds, searching and see what I can do with it with what I have. Looking forward to being around here for a while. Take a good look at it, wont be long and it gets a new wardrobe and facelift. |
06-11-2016, 06:46 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: New to ax10
When you can get the delux links that go with that chassis it will help you get your geometry set up correctly and pm or email the guy who makes your chassis and ask him what length shocks he recommends. He can also give you a good starting setup ie which chassis holes to start with and you can tune from there. That will help you get off to a good start. 149 r/c worx team driver Last edited by snapon boy; 06-11-2016 at 08:01 AM. |
06-11-2016, 11:43 AM | #3 |
Rock Crawler Join Date: Sep 2009 Location: Bloomsburg, pa
| Re: New to ax10
i think he is talking about ti link from dluxfab
06-11-2016, 12:16 PM | #4 |
Rock Crawler Join Date: Jul 2013 Location: california
| Re: New to ax10
welcome to the addiction that is rc crawling. I don't think the warthog chassis is made any longer so most likely your not going to find out much info on it, but do some searches see if you can find some old builds. weirdly enough I saw this on tv.The warthog was featured somewhere near the end the episode. Remote Control Rock Crawler Build! | Xtreme 4x4 | PowerBlockTV - Full Episodes Anyway when you get you new chassis your going to want to get some new shocks (traxxas bigbores or scx10 shocks). Also, what electronic are you running? I also agree with the others and get some ti links from dlux fab. you have to pm Dlux and I think he make you a custom set of links or you can make your own out aluminum pipe or rod. there is a thread somewhere on here that explains how to do it. |
06-11-2016, 12:23 PM | #5 |
| Re: New to ax10
Yes delux fab makes the links for that chassis there on his Web site. 149 r/c worx team driver Last edited by snapon boy; 06-11-2016 at 12:29 PM. |
06-22-2016, 08:04 PM | #6 |
| Re: New to ax10
Took some time getting it running. UC fastback axial clockable c hubs xxl big bores with losi mini T springs Novak 55T AE-5 esc CC bec 3s 1350mah lipo 75c 2.2 proline chisels, star cut memory foam with 6oz each up front and 30z each in rear Overdrive gears up front Ive tinkered around with links a bit and had to change the front shock mount locations because of length (no cap mod yet). Right now it has some old axial uppers 4 linked in the rear just into the servo plate, custom bent lowers in the rear, straights in the front and 3 link uppers up front for now. It has been a fun transition. I'm able to get up lines I was no where near making with the warthog chassis, and with ease. 100% more capable right now and more link/shock tuning to be done. Otherwise I'm more than pleased with it. No binding or rubbing of any links, nice smooth articulation. Last edited by TraskRiver; 06-22-2016 at 08:08 PM. |
06-22-2016, 08:22 PM | #7 |
| Re: New to ax10
Look into a distroy front plate! 149 r/c worx team driver |
06-22-2016, 10:23 PM | #8 |
| Re: New to ax10
looks good. Before looking into the destroy plate, it isn't necessary for what your running, look into underdrive gears for the rear. You will notice a huge difference with ud gears in the rear.
06-25-2016, 11:07 AM | #9 | |
Should I under drive the rear to? From what I searched, if you have a slower turn motor it's best to over drive the front. If you have a faster (35t) you should under drive the rear. But there are also people installing both under drive and over drive. I plan on running a vp dig later down the road. I still need a high torque servo. When I do get one, how do I go about programming how much voltage to give it? Is that through the esc or the CC bec? Last edited by THX_138; 06-15-2017 at 08:42 PM. | |
06-25-2016, 12:13 PM | #10 |
| Re: New to ax10
Trust me do the underdrive in the rear. I ran a vp dig for a while before and after I did the under/over and my rig performed worse with the dig. I found that I wasn't using the dig once I got the under/over, and it just became weight up high,which raises cg. It is through the cc bec, you will need a castle link to do that. As for high torque servo I highly recommend the hitec 7950 or the holmes hobbies servo Last edited by Dezertdirt; 06-25-2016 at 12:16 PM. |
06-25-2016, 03:05 PM | #11 |
| Re: New to ax10
I don't think you will need the dig but under drive and over drive will help. You will need eventually a solid one pice out drive Holmes Hobbies or hot racing your call. The over and under drive can break the screws in the stock outdrives. 149 r/c worx team driver Last edited by snapon boy; 06-28-2016 at 01:37 PM. |
New to ax10 - Similar Threads | ||||
***Axial AX10 Trannys shipping *** PLUS AX10 Straight Axle Giveaway*** | Rockpiledriver | RCP Crawlers | 142 | 12-19-2007 03:57 PM |
