Thread: Motor won't fit?
Old 03-04-2017, 10:59 PM   #1
Default Motor won't fit?
I have a stock Axial AX-10 scorpion and I bought a HH trailmaster sport. Problem is it won't fit the motor plate. Is there a way to remedy this? Or am I SOL?
Thanks
Blankenship24 is offline   Reply With Quote
Old 03-04-2017, 11:11 PM   #2
Default Re: Motor won't fit?
Are you sure you're trying to use holes that are straight across from each other?
WHITE-TRASH is offline   Reply With Quote
Old 03-04-2017, 11:17 PM   #3
I'm pretty sure. I looked at it multiple times to make sure. The motor doesn't sit right. I can get the silver metal piece where the pinion gear sits through fine but the circular area below is where I have trouble. Won't cross the hole. Sits very awkward.
Old 03-04-2017, 11:44 PM   #4
Is the shoulder too large to fit in the hole? I've seen that happen where the motor plate needed to be opened up a little hit to allow the motor to fit.
Old 03-05-2017, 12:08 AM   #5
Yes, that sounds exactly right. I didn't know it was a shoulder though. So what's the best way to open up the plate a bit? And thank you for the replies
Old 03-05-2017, 07:56 AM   #6
A round ("rat tail") file or a small sanding drum on a dremel will make short work of it.
Old 03-05-2017, 10:16 AM   #7
Talking Re: Motor won't fit?
Thanks
Motor won't fit? - Similar Threads
i need a part # for a motor plate to fit a 1/8 brushless motor to my maxx mudd_slinger Traxxas Crawlers 1 03-10-2014 09:55 AM
Does an 1/8 motor fit? Cmarcan167 Axial Wraith 30 02-04-2014 02:41 PM
motor just won't fit williamsfw2427 Axial SCX-10 9 01-04-2014 06:26 PM
which tacon motor will fit ? yoda316 Losi Mini-Rock Crawler 7 11-02-2011 02:09 PM
Would this motor fit? TurnThePage Chit Chat 15 09-07-2009 05:17 PM
