03-04-2017, 10:59 PM | #1 |
Newbie Join Date: Mar 2009 Location: Cali
| Motor won't fit?
I have a stock Axial AX-10 scorpion and I bought a HH trailmaster sport. Problem is it won't fit the motor plate. Is there a way to remedy this? Or am I SOL? Thanks |
03-04-2017, 11:11 PM | #2 |
| Re: Motor won't fit?
Are you sure you're trying to use holes that are straight across from each other?
03-04-2017, 11:17 PM | #3 |
I'm pretty sure. I looked at it multiple times to make sure. The motor doesn't sit right. I can get the silver metal piece where the pinion gear sits through fine but the circular area below is where I have trouble. Won't cross the hole. Sits very awkward.
03-04-2017, 11:44 PM | #4 |
Is the shoulder too large to fit in the hole? I've seen that happen where the motor plate needed to be opened up a little hit to allow the motor to fit.
03-05-2017, 12:08 AM | #5 |
Yes, that sounds exactly right. I didn't know it was a shoulder though. So what's the best way to open up the plate a bit? And thank you for the replies
03-05-2017, 07:56 AM | #6 |
A round ("rat tail") file or a small sanding drum on a dremel will make short work of it.
03-05-2017, 10:16 AM | #7 |
Thanks |
Motor won't fit? - Similar Threads | ||||
i need a part # for a motor plate to fit a 1/8 brushless motor to my maxx | mudd_slinger | Traxxas Crawlers | 1 | 03-10-2014 09:55 AM |
Does an 1/8 motor fit? | Cmarcan167 | Axial Wraith | 30 | 02-04-2014 02:41 PM |
motor just won't fit | williamsfw2427 | Axial SCX-10 | 9 | 01-04-2014 06:26 PM |
which tacon motor will fit ? | yoda316 | Losi Mini-Rock Crawler | 7 | 11-02-2011 02:09 PM |
Would this motor fit? | TurnThePage | Chit Chat | 15 | 09-07-2009 05:17 PM |
