Thread: 2.2s body mount
Old 07-19-2018, 10:43 AM   #1
Default 2.2s body mount
How are you guys mounting bodies? I tried standard pins but pins go missing and the posts aren't that strong. I know gunner used to make mounts but I think he has stopped production.
Dezertdirt is offline   Reply With Quote
Old 07-20-2018, 10:35 PM   #2
Default Re: 2.2s body mount
Ok, I've searched everywhere, I can't find gunner mounts or anything else that doesn't use pins. So, is anyone willing to explain how to make mounts? Does someone sell a mount?
Old 07-21-2018, 12:23 AM   #3
https://rover.ebay.com/rover/0/0/0?m...2F302787868674
Someting like these will work.
tapped-out is offline   Reply With Quote
Old 07-21-2018, 12:26 AM   #4
Look @ rear mount
Sent from my SM-J727VPP using Tapatalk
Old 07-21-2018, 12:33 AM   #5
Hope this helps...
Old 08-05-2018, 01:08 AM   #6
Fish's Crawler Parts sells mounts. I use them on everything. @snaponboy
https://www.facebook.com/FishsCrawlerParts/
doug.steele04 is offline   Reply With Quote
Old 08-06-2018, 02:32 PM   #7
small p clips. and some nylon parts from the hardware store. I just use a wing nut with the ears cut off.
the fcp mounts are really nice. I would just not use them in place of a chassis brace though. the shapeways sls still has some flex to it.
CM9000 is offline   Reply With Quote
2.2s body mount - Similar Threads
How to mount tamiya Hilux body with drop bed on my scx10? Body sits too high. liftmys10 Axial SCX-10 8 02-13-2014 09:57 AM
Idea for Body mount / Clod Buster body / SCX10 Dingo fxman Axial SCX-10 7 07-19-2013 10:27 AM
How to mount body with no body clips or holes? ProfitOfDoom Axial SCX-10 9 04-16-2013 05:03 PM
