| | #1 |
| Rock Stacker Join Date: Mar 2004 Location: wasatch front
| (yes its me, and yes i finall got another truck to drive over rocks with) Ok here is the issue, while placing the pivot ball in the upper center axle link mount i saw a small crack start. I thought that it was just that individual link mount but as i did the other side the same thing happened. now they are not cracked all the way through but time will tell. If this is happening to everyone then it is a manufacturing issue that needs to be addressed. Anyone else with this problem? have any broken all the way through? |
| Sponsored Links | |
| | #2 |
| Rock Crawler ![]() Join Date: Jan 2007 Location: monson
| | #3 |
| Rock Stacker Join Date: Jul 2007 Location: A-pop-kuh, FL outside Orlando
| you could try tapping the hole first. that is what i do before assembly. |
| | #4 |
| Newbie Join Date: Jul 2007 Location: Reno
| I believe the portion jtothec was referring to is the pivot ball that gets pressed into the mount. I could easily be wrong though. This part you wouldn't tap. FYI, mine didn't crack. |
| | #5 |
| Newbie Join Date: Aug 2007 Location: Quad Cities
| mine didnt crack but to put the flange ball in the links i took my cross wrench the biggest hole and put the flange ball on the table. Then i set the link on top of the flange ball and used the cross wrench to push down so that it could go through the hole of the link and wrench |
| | #6 |
| Newbie Join Date: May 2007 Location: MossLanding
| I did the same as dirt trak racer and had no problems. These are great rigs, I love it you can't beat the price. |
| | #7 |
| Newbie Join Date: Apr 2006 Location: WJ
| Mine didn't do that at all when I was pressing it in. I did however have a problem with one of my axles though. I went to slide on one of the bearings and it wouldn't get past the first section because the metal wasn't completely shaved down. Had to get out the 'ol dremel tool and grind it down slightly. No biggy but first time out of 16 kits (just any kit including the axial) i've built that i've ever had a problem like that. |
| | #8 |
| Rock Crawler Join Date: Dec 2005 Location: Borderland Tejas
| That was the one thing i kept wondering about last night when I was looking over these threads looking at the axles. I would like to use them in my next build maybe but the lower link mounts scare me. Atleast with the tlt mounts, if they break you can just bolt on some new ones. With these being plastic and having the forces of the suspension links and shocks being put on them and also drug over rocks, how long will they last? And if they break are you screwed or is there enough clearence to drill the case to accept tlt link mounts? Everything else about the axle seems to be up to par with the tlt axle or better which is great. The internals or no big deal because I'm sure RCP and the rest of the venders are already working on cvds and other upgrades. It's just the plastic link mounts that worry me. |
| | #9 |
| Quarry Creeper Join Date: Jun 2004 Location: 462-Da Fock
| Is there any room to drill a couple holes to mount on an aluminum channel piece to make new mounts? some flat head screws from inside out and then bolt the angle piece on. Just a thought. I havent seen the axles up close. Last edited by spiderxx; 08-23-2007 at 04:32 PM. |
| | #10 |
| High Plains Drifter... ![]() Join Date: Oct 2006 Location: Sterling VA
| The lower link mounts are molded into the axle case??? So if you break one, that's that? Hmmmm... |
| | #11 |
| i got mine yesterday and im pretty much done with it im waiting for my rooster crawler esc before i can finish it all i have to do is install my esc and reciever and my battery plate on top so i can put on my electronics |
| | #12 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| Welcome back J. Missed ya. |
| | #13 |
| Rock Stacker Join Date: Oct 2004 Location: Marina Del Rey
| well the mounts have the same problem as the wheelie king, if you break the wk lower link mounts you need to order a parts tree that includes axle cases. its a $10 fix on the wk, unless you know of somewhere that just sells the lower link mounts. Has anyone actually ever broken a link mount on any other truck, or just the rod? |
| | #14 |
| Quarry Creeper Join Date: Nov 2004 Location: Mid TN
| Well, if it means anything I've broken just about everything but the lower link mounts on a WK - I don't think it'll be a problem unless you drive one off a cliff, and even then, it's apt to be the last thing to break. |
| Thread Tools | |
| Display Modes | |
