| | #1 |
| Newbie Join Date: Aug 2007 Location: Baltimore-Washington Corridor
| I'm planning to purchase an AX-10 as my first foray into rock crawling. I' hope to get a brushless motor and ESC to put in it, since I am quite a fan of brushless technology. I'd like to ask those members of the forum who are more knowledgeable on this topic---in other words, all members of this forum---a few questions:
Thank you for your attention. I look forward to hearing from you. Last edited by skeeler; 08-24-2007 at 02:06 PM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Nov 2004 Location: Mid TN
| I'm not going to speak on the battery situation, because I don't currently use LiPo myself - although I will confess to being a power junky. I'm using a Scorpion 3014 from holmeshobbies.com and running from a quark33 - I've heard people talk about this setup and compare the quark and mamba max, so I figured I'd try it, since I have a MM already. I view my AX-10 as being more of a precision instrument, compared to my WK, which is more like a sledgehammer. The MM in that is pushing a crawlermaster running 14.4 volts and it'll break parts on demand. |
| | #3 |
| Thanks for your reply. Any more motor/ESC suggestions? |
| | #4 |
| Rock Crawler Join Date: Jun 2007 Location: Flint/Mt. Morris
| I am looking at the same thing for my ax10. I think that I am gunna get Holme's budget combo and order a stronger motor later. I only wondered about the strngth of the trans. I think it should be fine though unless I go overkill as usuall with a huge motor. |
| | #5 |
| Newbie Join Date: Aug 2007 Location: Austin
| I'm looking at a couple lower-cost brushless setups. I'm wondering about the mamba25 with the GWS-12 motor from HH, or the BM9 from TCS. Then run a 6 or maybe 8 cell pack, the latter since the GWS is described in other threads as needing a bit more voltage to wake up (3s lipo, for example). Either of these motors with a mamba25 runs about $100. The GWS-12 is described as being good for lighter 2.2 rigs. Does the AX-10 fall into that category? |
| | #6 |
| Rock Crawler Join Date: Apr 2007 Location: portland
| Novak brushless crawler system. |
| | #7 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| A bm-9 with a quark 33 would be sweet, not to much power but would still break a few things, also a 3 cell lipo is a good idea. |
| | #8 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| Finally got around to putting mine together. I'm using the BM9 and a Mamba 25, along with an Elite 1500 2/3A pack. I also have a couple of Thunder Power 1320 mah 2 cells Lipos, and feel that they're better than the Elite pack. But the Elite pack has more weight to it, so I'm going to run with it for a while. The Scorpoin is so light on it's own, that I figured this is a good way to add some weight up front. ![]() The BM9 works nicely with this set up, as the truck is rather light, and the motor has decent power anyways. There's a 12 tooth pinion on the motor, and it's still fast enough for me. |
| | #9 |
| Quarry Creeper Join Date: Apr 2007 Location: Katy, TX
| Thanks EeePee. I now know where to put my elite 8cell pack. Does anyone know when that servo mount and battery tray will be available? It shows the picture in the manual listed under optional parts. Thanks. Tyler |
| | #10 |
| Newbie Join Date: Aug 2007 Location: Canada
| would a hitec 925mg be too fast for these trucks? or should i get the gears to change it to a 945. Right now its 110oz @ .08sec |
| | #11 |
| It won't be that fast with the tires on the ground, if it turns them at all. |
| | #12 | |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
For a good brushless motor, I would either recommend the Novak crawler system or a decent size outrunner. For the easiest tuning a 3.5 ounce outrunner is best. The Crawlmaster or Revolver black fits the bill nicely. Smaller motors need more voltage, larger motors break parts. It sounds like you want to run 2s, so that is my basis for the recommendations. As for capacity, 1300 mah 15C packs would be the minimum IMO. Larger is always safer. As for the ESC, the Quark ESCs are the smoothest right now. The Castle ESCs are certainly easier to program though, and still usable and crawlable. The nice thing about a mamba max is that it will run brushed motors. The Novak crawler system also runs brushed motors, but not sensorless brushless. | |
| | #13 |
| Pebble Pounder Join Date: Jun 2007 Location: Las Vegas
| Skeeler If you pick up the latest copy of RC Driver, there is an article Jason wrote on the Novak Crawler system that he installed in Ralph. |
| | #14 | |
So converting it to 945 with a gear swap would be idea then.. IT will bump it to 180oz and be a touch slower... What is considered the minimum torque needed for a crawler with lizard/moab sized tires anyway? | |
| | #15 |
| Dont jack the thread bud lol. What is it going in though? For an Axial, I am scared of going 200oz because the knuckles look delicate. In a 2.2 around 200oz should be cool. I figure 300oz are just gunna be alu knuckle benders lol. Back to the Brushless. I am gunna use a quark ESC, not sure on the motor but I am trying to get a medium one like the crawler master. We will see. |
| | #16 |
| I have a tp945 in mine, seems adequate. |
| Thread Tools | |
| Display Modes | |
