Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: AX-10 Bronco Build
Old 08-27-2007, 07:17 PM   #1
Default AX-10 Bronco Build
Unless your building anything other than the box art truck, then all these builds will look the same, but what the hell....
My first impressions wo/ any drive time in it. Very easy build, even a monkey could put this truck together, so most newbies should get it. The parts needing to be addressed by aftermarket folks, and I know some are already working on that is the axles c's, knuckles and upper axle link mount will need to be aluminum. A front servo/battery mount will be nice for those of us that use the stick packs. The shocks should be alright, but I may upgrade mine only b/c I have a few sets sitting around. Ditching the Betty Body only b/c most others will use it, so needed something different.
I'm going to need to leave the tires outside b/c they are stinking up the house. Just got that new tire rubber smell worse than most tires. No big deal.
AX-10 Bronco specs:
Novak Crawler Rooster ESC
Hitec 5645 servo
JR XR3I radio
Integy 55t motor w/ 13t
Weights inside tires
Battery will be located on servo until new mount is produced by others
Bronco Body - just imagine it's painted already
Sorry, but the pic's are not the best. Wasn't going for photographical perfection.
bbyrd22 is offline   Reply With Quote
Old 08-27-2007, 08:01 PM   #2
Looks good. Im running the Bushwacker body on mine once I get longer posts, I think the Betty Body is hideous.
Eric_N is offline   Reply With Quote
Old 08-27-2007, 08:13 PM   #3
Are you needing longer posts for mounting it on the sides, or you are going up with the mounts. Curious because I love the Bushwacker body also.
NitroStar is offline   Reply With Quote
Old 08-27-2007, 08:20 PM   #4
I play with TOY TRUCKS
Rpp Hobby's Avatar
Looking good
Rpp Hobby is offline   Reply With Quote
Old 08-27-2007, 08:20 PM   #5
Longer posts for the sides. Right now when I put the body on the posts just touch the sides of the body, so 1/2" longer posts should be just right.
Old 08-27-2007, 08:31 PM   #6
looking sweet !!!!
kaaina is offline   Reply With Quote
Old 08-28-2007, 04:59 PM   #7
I love the bronco body. I'm going to pick one up today. My betty body didn't turn out like I wanted it to.
Xaja is offline   Reply With Quote
Old 12-11-2007, 12:01 AM   #8
2 1/2" body posts are the key for bronco bodys on the scorpion perfectttt fit
Larson627 is offline   Reply With Quote
Old 12-11-2007, 09:58 AM   #9
Nice it looks just like mine did before I switched to a x-trail chassis.
Ax-10Canadian is offline   Reply With Quote
