08-29-2007, 11:29 AM | #1 |
Newbie Join Date: Mar 2007 Location: Blue Ridge, GA
| Battery pack setup
I have not assembled my ax-10 yet and have a quick question. Whch on of these packs would work better on thw ax? Also will there be enough room to mount them on the links or front axle? http://www.tcscrawlers.com/product.p...cat=123&page=1 http://www.tcscrawlers.com/product.p...cat=123&page=1 |
08-29-2007, 11:43 AM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: NOR*CAL
the first one thats in the shape of a six pack, and yes it will fit just fine..
08-29-2007, 11:46 AM | #3 |
I use the stick pack (second link) on my competition rig and love it. It sits lower than the brick. I velcro mine to the top of the servo but you could also cut and zip tie a piece of lexan to the upper links to make a platform for it to sit. |
08-29-2007, 11:46 AM | #4 |
Quarry Creeper Join Date: Apr 2007 Location: Katy, TX
Well it depends on your motor/esc setup. What are you using? The first one will fit on the side of the axle. You may want to go with tcs's 8 cell pack for more power if your setup can handle it.
08-29-2007, 11:51 AM | #5 | |
what could handle it?? i'm new to electric stuff, but i got a rooster crawler.. should i step up to a bigger pack?? whats the benifit other than run time?? | |
08-29-2007, 11:58 AM | #6 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Rooster crawler is only rated to 7 cells nimh. You could probably get away with 8 cells, but might have heat problems. Definitely wouldn't be warranteed if you toasted the esc. More cells = more speed/torque/power Higher ratings = longer run time Chris |
08-29-2007, 12:07 PM | #7 |
Will the stick pack work with a moped ESC and a 55t?
08-29-2007, 12:10 PM | #8 |
08-29-2007, 12:23 PM | #9 |
well the rooster crawlers description says it can handle 4-7 cells nicd-nimh. Upping the cells means more voltage, resulting in more power. *edit* I guess I just echoed what ecoli said Last edited by tsaun987; 08-29-2007 at 12:26 PM. |
08-29-2007, 12:34 PM | #10 |
Will the connector on the stick pack work with the moped ESC or will I need to change one of the two?
08-29-2007, 12:35 PM | #11 |
08-29-2007, 05:29 PM | #12 |
Pebble Pounder Join Date: Sep 2006 Location: Norfolk, VA
Both packs listed come with Deans Connectors and the Moped has a Tamiya style connector stock. You would be best off to change the Moped to a Deans for less resistance.
