08-29-2007, 12:02 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: NOR*CAL
| springs or not??
anyone running springless due to the super stiff stock setup?? if so, how it handle? |
08-29-2007, 12:03 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I am running stiff internals.
08-29-2007, 12:07 PM | #3 |
be more specific,, i'm new to crawling |
08-29-2007, 12:10 PM | #4 |
Sorry. I found some C-620 springs at a local hardware store. I run them inside the shocks under the shock piston for a droop effect. They suck the pistons in vs. the normal way. I do not run an external spring. |
08-29-2007, 12:37 PM | #5 |
right on.. what result is seen from doing this?? |
08-29-2007, 12:39 PM | #6 |
i understand that it wants to keep them compressed instead of extended.. but why?? |
08-29-2007, 12:56 PM | #7 |
That kind of shock will make your rig have a lower cog, better handling on some situations, better sidehilling capabilities, do a search on droop set ups. Also check this small video with a shock with an internal spring. Droop shocks? |
08-29-2007, 12:57 PM | #8 |
thanks caltron
