09-01-2007, 05:04 AM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Rocklin, CA
| best found mods
Lets here what mods you have done and work best for you. Link position, shock setup, motors, lets here it all. So far I have put the shock damper on the inside to limit the shocks toget a lower cog. Also used Jasons idea on the 2 spacers on the rear left shock, big difference! Washer on upper link. Took out tire foams and filled tires up with the green airsoft BBs from Wal-Mart. Added the weight I wanted low and get great grip. So lets here yours |
09-01-2007, 08:58 AM | #2 |
Rock Crawler Join Date: May 2006 Location: Georgia
I also limited my shocks on the inside using fuel tubing about 1/2in long. I also kept the limiters on the outside as well. Still have about 5-6 in of articulation. Added some AE springs #1582 green, silver You could also remove the screw on the c hub closest to the steering knuckle. At max steering throw the knuckle hits this screw. With the screw removed the knuckle will sit flush against the axle c at full turn. I have only bench tested this mod, im not sure how well the axle c will hold up with only 1 screw holding it on. I built a lower skid out of delrin to triangulate the lower links, this got rid of all the axle steer but I destroyed the plate.:-( I will be making another. |
09-01-2007, 09:07 AM | #3 |
RCC Addict Join Date: Nov 2005 Location: Utah
Weight T-maxx big bore aluminum shocks Losi Claws Mount electronics under the battery tray Cut out a sheet of lexan, zip tie it to the rear upper links, set your lipo on there. Cut out notches on the skid so the links can mount on the inside, then use a screw on the closest hole in to hold the skid |
09-01-2007, 09:46 PM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| My Upper Link Washer and screw fix
I know everyone is adding the washer, those who are keeping the stock set up for awhile that is. I found the stock cap head hits the axle, which could be causing un-due stress and more popping. So instead I used a 3x15mm Flat Head screw with the same washer, MUCH more give so far. Pics: |
09-02-2007, 01:22 AM | #5 |
Quarry Creeper Join Date: Apr 2007 Location: Harrisville, UT
A button head might work even better, 4.5 oz of plastic bb's in each tire customized venom 3000 pack swapped the rear c's and put the knuckels front facing for max rear clearance MT2 aluminum shocks and of course the washer fix on the upper link mounts Last edited by screaminsavage; 09-03-2007 at 03:21 AM. |
09-02-2007, 01:37 AM | #6 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
| bbs
why bb's to wieght the tires there is other methods
09-02-2007, 03:31 AM | #7 |
the bb's put the weight at the lowest place possible, they also conform to the rocks well
09-02-2007, 02:17 PM | #8 |
Just got back from Folsom Lake. I love this thing! I beat the hell out of it and nothing broken. The BB's work great in the tires, good traction. Still think I might have to get the losi claws. Might have to try the rear knuckle swap. Thanks for the idea.
09-02-2007, 02:21 PM | #9 |
I wanna be Dave Join Date: Dec 2006 Location: here
rear dig |
09-02-2007, 03:28 PM | #10 |
Quarry Creeper Join Date: Aug 2007 Location: NOR*CAL
JUST BB'S IN THE TIRES?? no foam at all?? airsoft bb's?? |
09-02-2007, 04:07 PM | #11 |
Just airsoft BB's, no foam. I'm going to try and use a mixture of airsoft and regular bb's to add some more weight to the front. Let you know how it works.
09-02-2007, 07:14 PM | #12 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
09-03-2007, 01:03 PM | #14 |
Newbie Join Date: Jul 2007 Location: wyotech
what is this washer somewere mod that everyone is talking about? can somebody post some pics of it and like a detailed explination please
09-03-2007, 01:05 PM | #15 |
| i tried that on my j2/tlt... wayyy too heavy!! just airsoft alone was too heavy... the best ax-10 mod ive seen is a new chassis and suspension..
09-03-2007, 01:29 PM | #16 |
09-03-2007, 01:48 PM | #17 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
used the top plate as a battery mount: |
09-03-2007, 03:44 PM | #18 |
the pics in post 4 arent showing, theyr just white boxes with x's in them, does anybody else have any pictures of the washer mod? thanks
09-03-2007, 03:46 PM | #19 |
09-03-2007, 05:36 PM | #20 |
| I just re-checked them to be 100% working...When you assemble the upper link to the axle, put a washer behind the screw, a 3mm washer works. I found using a 3x15mm Flat or Button head screw with a smaller Stainless 3mm washer to provide me with no clearance problems and I've have no pop outs yet.
