09-06-2007, 12:41 PM | #1 |
Newbie Join Date: Jul 2007 Location: Texas
| Tires rubbing lower links
I just finished building my Scorpion and The first thing I noticed was that the tires were rubbing the lower links. I assume this is not a good thing. What is the best way to stop this? I have the steering link screw in the bottom hole of the horn, if I move it up a couple of holes will this fix the problem?
09-06-2007, 12:49 PM | #2 |
Rock Stacker Join Date: Oct 2004 Location: Marina Del Rey
It should do, considering you don't have a servo that is getting something like 180 degrees of rotation.
09-06-2007, 12:55 PM | #3 |
Its really not a problem, i wouldnt worry about it. The tires slightly rub the shocks at full lock on my 2.2 comp rig...
09-06-2007, 02:00 PM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
And you could always run less EPA if you happen to have that feature on your radio.
09-06-2007, 02:15 PM | #5 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
i noticed this too, i set the EPA to stop it, but it doesnt seem to have that much steering. Well i dont know what to compare it too, 1/8 buggies have insane steering.
09-06-2007, 04:19 PM | #6 | |
Quarry Creeper Join Date: Aug 2007 Location: NOR*CAL
compare it to a car with no steering at all.. the scorp is almost that good ....lol seriously , ive had nitro vehicles, buggies , monsters , mini's, and the crawler wont turn for $%#&.. time to learn how to wheel buddy.. | |
09-06-2007, 04:54 PM | #7 |
Rock Stacker Join Date: Apr 2007 Location: Canadia
What servo are you running that your saying it turns bad? Mine turns really nice you must have something in your linkage messed up.
09-06-2007, 04:56 PM | #8 |
Rock Stacker Join Date: Sep 2005 Location: Oregon City
If the tires are turning far enough for them to hit the lower links, you're seeing about as much as the rest of us. Just need to understand that locked trucks don't steer well on high traction surfaces such as carpet, asphalt, and concrete. That's just the way it is.
09-06-2007, 05:13 PM | #9 | |
i think when i run internal springs i can move the washer to the outside moving the link a mm away from the tire, not much but.............. | |
09-06-2007, 11:05 PM | #10 |
Once you're on the rocks and start unloading weight from the tires, it'll steer better.
09-09-2007, 01:49 PM | #11 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
| remedy...
i noticed the same thing... what i did to fix it.. was on the lower links.. i moved them inward.. and put the shocks on the outside...links on the inside..
09-09-2007, 01:51 PM | #12 |
