09-08-2007, 02:27 PM | #1 |
Rock Stacker Join Date: Jun 2007 Location: carmel
| parts needed
Anyone know where I can buy the battery/servo combined plate and a RWS setup for the AX10? thanks in advance cwkoehler |
09-10-2007, 12:36 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: Redmond
Yeah,, I traced my stock on onto a peice of Aluminum plate, then widened the shape, moved the holes for the servo, and it's perfect, took maybe 5 minutes to make, made all the difference to the truck. |
09-10-2007, 09:33 PM | #3 |
I joined the Band! Join Date: Jun 2007 Location: wisconsin
i couldn't wait any longer also.. i make up my own linkage from 1/4 solid aluminum rod (purchased at fleetfarm for $1.50 3ft.) center drill a 2.5-2.6mm diameter hole in the ends.. thread in a long 3mm bolt, cut off the head and thread on some of the spare ball ends that come with the ax10 kit.. as for the servo/battery mount... flat aluminum (same gauge as stock peice) trace original, than add some on each side and there you go!! good luck |
09-11-2007, 09:22 AM | #4 |
Good idea kill the thread |
