09-17-2007, 02:22 AM | #1 |
Quarry Creeper Join Date: Aug 2005 Location: Tucson
| how do you shorten the shocks
how do you shorten the shocks and which springs work the best? Just wondering if anyone has mod there shocks. The stock shocks feel to stiff..
09-17-2007, 05:24 AM | #2 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
once their mounted they dont actually feel that stiff anymore their is loads of flex, but to shoten them you can put some fuel tubing under the piston inside the shock.
09-17-2007, 05:58 AM | #3 |
Pebble Pounder Join Date: Jul 2007 Location: A-pop-kuh, FL outside Orlando
ditto on the tubing. you can also use the small nylon/plastic washers found in just about any kit. Or, you can use some inner springs (pen springs) under the piston to have varied shortness.
09-17-2007, 06:35 AM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Well just shortening the shocks only makes the spring "stiffer". As eveyone has said fuel tube or washers, some use the plastic spare ball links on the let over plastic tree parts. But taking a long shock with long spring and shortening it and using the same spring basically gives to massive preload. Even stiffer. |
09-17-2007, 10:54 AM | #5 |
Newbie Join Date: Jun 2006 Location: B_town, CO
Increasing preload will technically only make a spring stiffer if it is a progressive spring, not when its a linear spring.
09-17-2007, 11:01 AM | #6 |
Pebble Pounder Join Date: Jan 2007 Location: H D
one inch fuel tubing under the piston
09-17-2007, 02:38 PM | #7 |
Quarry Creeper Join Date: Aug 2007 Location: NOR*CAL
1 inch is waaaaaay to much.. i did less than a half inch and love it..preload and all it almost killed the torque twist completely.. still flexes no problem.. |
09-17-2007, 02:48 PM | #8 |
09-17-2007, 04:28 PM | #9 |
I wanna be Dave Join Date: Dec 2006 Location: here
spare ball links on the let over plastic tree parts. is the way to go 2 inside ea. shock works good. thats what i did xtm X-C springs. but going to use hpi mt springs their 80x14mm. |
09-17-2007, 05:52 PM | #10 | |
Pebble Pounder Join Date: May 2004 Location: Portland or
I also used a 1" spacer in my stock shocks. It works very well and gets the ride height down to a comp worthy status. I have no torque twist and a reasonable amount of flex but a truck that is very planted on any surface. Sean | |
09-17-2007, 09:11 PM | #11 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
1/2" tubing inside works extremly well!!!
09-17-2007, 09:14 PM | #12 |
Pebble Pounder Join Date: Apr 2006 Location: reno
use the spacer it came with to put on the out side and move it under the piston then use hpi mt2 springs (yellow works but might be a little too soft) i know king bling is running that set up and i think the Axial guys ran that and NATs Last edited by doctorducttape; 09-17-2007 at 09:21 PM. |
09-18-2007, 04:13 PM | #13 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
I played around with shortening the stock shocks for a while but ultimately I decided to replace them. I didnt want to run a shock that wasnt right for my setup and just rig it to make it work. I wanted the right shock length so I could tune it from there. I took my scorpion to the LHS and had them grab me just about every shock they carried even down to the Losi MiniT shocks. After lining them up to see what was the best length to the geometry I was looking for I bought a set of Duratrax Evader shocks which are aluminum bodied with full thread for pre-load adjustment. The set cost me $34.99 and my LHS has high prices. After installing the new shocks my rig crawls better than ever. The suspension outperforms the stock Rock Lizards now and the only thing stopping me from walking straight up or sidehilling a 70º+ angle is the crappy tires not gripping. I cant praise the Evader shocks enough. They are great on these rigs....
