10-03-2007, 07:25 AM | #1 |
Newbie Join Date: Mar 2007 Location: Blue Ridge, GA
| Quick Help ?
Some how I must have striped out one of the bolts that holds the motor plate to the trany and it just came out last night. Any quick fixes to hold untill I can find a new one? |
10-03-2007, 07:36 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I think if you use a button head and go in the other way and used a nut on the tranny side it would clear. So the button head would be on the motor plate... You sure it didn't just vibrate out? |
10-03-2007, 07:48 AM | #3 |
Yeah , Im sure. I will give that a try. Anybody know the size of that bolt off hand? I am at work and cant get the Axial page to load.
10-03-2007, 08:27 AM | #4 |
Never mind I found it m3x25mm
10-03-2007, 08:31 AM | #5 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Is the bolt stripped or the threads in the tranny? If it's the tranny, no point getting a new bolt. I'd just wrap the bolt in teflon tape and add loctite and hope for the best. Otherwise, you may have to drill and tap it for a larger bolt (if possible).
10-03-2007, 09:05 AM | #6 |
RCC Addict Join Date: Jan 2006 Location: The Amish Ghetto
just use the botton head method, longer screw and a nut will solve the problem |
10-03-2007, 12:00 PM | #7 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
i did the same thing i just put tons of lock-tite on there and never had a problem, but i buying a different tranny anyway.
